lil problem. plz help.
Old Feb 14, 2007 | 08:05 PM
jdm_dc_199's Avatar
Default lil problem. plz help.
ok. so my car(95 integra) had a CEL 4(crank position sensor), and from what ive heard, its the dizzy that i need to change. so i did(bought a new dizzy), and it still has the same problem. it has hard time starting, wont rev past 3500rpm. does anyone know how i can fix this or what i need to do to get this running?
thanks,
and yes, i did search. found nothing
Old Feb 15, 2007 | 09:22 AM
jdm_dc_199's Avatar
anyone?
Old Feb 15, 2007 | 06:26 PM
jdm_dc_199's Avatar
come on ppl. i need some help.
Old Feb 15, 2007 | 07:00 PM
blkb18's Avatar
Default Re: lil problem. plz help. (jdm_dc_199)
The sensor in your dizzy is your cam position sensor, you should have a separate crank position sensor down by the crank.
Old Feb 15, 2007 | 07:02 PM
qfast817's Avatar
Default Re: lil problem. plz help. (blkb18)
but a 95 gsr dosent have one. obd2 and up
Old Feb 15, 2007 | 07:09 PM
blkb18's Avatar
Default Re: (jdm_dc_199)
Did you check the wires from the dizzy to the ecu? Also did you set your timing when you installed the new one?
Old Feb 15, 2007 | 07:25 PM
jdm_dc_199's Avatar
yes and yes. i was told that when you do timing, it should line up on the red line on the pulley. well anyways, the dizzy was as far back as it could go and it still didn't reach the red line. what do you think could cause that? do you think their could be a problem with the actual crank?
oh and i took the valve cover off, and i noticed that the timing belt had slipped a tooth. so i fixed it and didnt fix the problem.
Old Feb 15, 2007 | 07:56 PM
blkb18's Avatar
Did you jump the connector near the ecu before you checked the ign timing? (after you corrected the valve timing of course)
Old Feb 16, 2007 | 12:35 PM
jdm_dc_199's Avatar
no i didnt. is that what your suppose to do?
Old Feb 16, 2007 | 05:18 PM
blkb18's Avatar
at least on my 96 it is, i dont know if its different on an obd1.
Old Feb 19, 2007 | 08:40 PM
jdm_dc_199's Avatar
is their any way that the ecu could have anything to do with the problem? its a chipped ecu that i bought from hondamarketplace.
Old Feb 20, 2007 | 07:22 PM
jdm_dc_199's Avatar
cmon, someone has to know the answer to my problem
Old Feb 20, 2007 | 07:26 PM
GsrIntegra789's Avatar
ya 95 gsr odnt have a crank postion sensor. so you might wanna recheck your code
Old Feb 20, 2007 | 07:36 PM
jdm_dc_199's Avatar
ya it does. the sensor is in the dizzy. and if it doesnt, then what is CEL4?
Old Feb 21, 2007 | 09:39 PM
jdm_dc_199's Avatar
bump for more info
2000siturboR
Nov 6, 2009 03:29 PM
kaddi88
Aug 25, 2008 05:14 PM
ahc'monracing
Sep 24, 2002 01:26 PM
