Firewall map sensor to a TB map sensor?
Old Oct 16, 2007 | 02:31 AM
da9blk1's Avatar
Default Firewall map sensor to a TB map sensor?
how and would that work? block of the hose from the firewall one...........run the hose too....?
anything?
Old Oct 16, 2007 | 02:41 AM
Duane_in_Japan's Avatar
Default Re: Firewall map sensor to a TB map sensor? (da9blk1)
MAP sensor reads vacuum right after the Throttle plate, they did away with the hose because there was a delay in vacuum reading when the throttle was opened, the longer the hose, the longer the delay, the voltage reading on both styles is the same, 3 wire MAP sensor, do not mount one to close to an intake runner going to a specific cylinder, getting further away from the Throttle plate shows signs of pulsations in the surge tank, thats the Japanese name for the large area of the IM, its a surge suppressor of sorts.
Use a vacuum plug to block off the old nipple on the IM.
bLu92bUbbLe
Jul 6, 2009 12:00 AM
guy_from_nerk
Feb 18, 2008 01:26 AM
allnaturalb16
Oct 19, 2007 10:14 PM
Topdawgg
Jun 25, 2007 10:02 AM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
