CEL please help..
Old Oct 16, 2007 | 11:51 AM
standbackimapro's Avatar
Default CEL please help..
Friend has a B16, The ecu is whichever goes with that engine ( pr4 maybe)?
anyway its throwing a check engine like.. the blinks on the ECU are
5 Fast pause. 2 Long, then 3 Fast.. Whats the code? or is it more than one code?
also is there a diagram or somthing to see how to run the vtec wires to the ecu
Old Oct 16, 2007 | 12:13 PM
sleeperrex's Avatar
Default Re: CEL please help.. (standbackimapro)
that would make it code 5 and code 23, manifold pressure and knock sensor
what obd is it....probably a p30
Old Oct 16, 2007 | 12:45 PM
What could the problems be though? i mean is it somthing causting those sensors to read bad, or could it just be a bad sensor?
The car dosnt havea check engine light on at first, then after u gun it, it comes on and it starts dumping fuel..
We tried replacing the MAP sensor but it still did the same things?
Old Oct 17, 2007 | 07:49 AM
up
Old Oct 18, 2007 | 02:37 PM
Anyone?
Old Oct 18, 2007 | 03:35 PM
Bev-Tech Inc.'s Avatar
Default Re: (standbackimapro)
find out for sure what computer he has. It's the middle numbers on the white label on the side of the computer.
hope this helps a little.
http://www.alldatapro.com/alld...39370
http://www.alldatapro.com/alld...39366
http://www.alldatapro.com/alld...36726
REDREXMANB16
Nov 23, 2006 09:54 PM
jetblack
May 16, 2006 06:20 PM
THE94GSR
Jun 25, 2004 05:07 AM
B00ST2nR
Sep 16, 2002 05:06 PM
.brad
Feb 26, 2002 03:30 AM
