Need help with electrical problem for lighting
Old Oct 12, 2007 | 02:59 PM
sublimnal's Avatar
Default Need help with electrical problem for lighting
So recently , i would say last week, my car running lights( corner lights , cluster meter lights, illumination for the dash and tailights dont' work
on the toggle switch for the light my 2nd click doesn't' work .
but wheni click it all the way my headlights still turn on .
The cluster icons for everything work but the cluster doesnt' illuminate.
the click works
the headlight , low beams and high beams work
my turn signals work it i use them , ex HAZARDS
but my tails lights are all shot unless i press the brake lights .
someone please help me
i dont know whats wrong
i have changed al the fuses and they are all fine.
here is a picture of my i integra ,
Old Oct 15, 2007 | 11:25 AM
sublimnal's Avatar
help me
Old Oct 15, 2007 | 12:28 PM
dizzzane's Avatar
Default Re: (sublimnal)
Beautiful ride man but I'm at a loss for you problem, hopefully some H-T wiring guru can send you in the right direction.
Old Oct 15, 2007 | 06:24 PM
sublimnal's Avatar
help
Old Oct 15, 2007 | 06:30 PM
soontobeboost's Avatar
did you take you your taillights or anything else lately? i had the same problem last time with my car when i took of the taillights. when i was putting them back in, i pinched one of the wires and had the same problem you do. check for pinched or cut wires. did you check the fuse book under the hood?
Old Oct 16, 2007 | 11:37 AM
sublimnal's Avatar
Default Re: (soontobeboost)
not from what i recall i didn't do any work with the electrical this pass few months
Old Oct 16, 2007 | 12:53 PM
qazaq's Avatar
relay? if i were you i would trace the signal (current) with a voltmeter relying on a circuit diagram of lighting...
Old Oct 16, 2007 | 03:49 PM
dickdragon's Avatar
that **** happened to me once.. it was my fuse, duh!
Old Oct 16, 2007 | 05:14 PM
sublimnal's Avatar
Default Re: (dickdragon)
i check the fuses and replaced them all too
Old Oct 16, 2007 | 05:45 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: Need help with electrical problem for lighting (sublimnal)
pm'd
Old Oct 16, 2007 | 06:07 PM
coupeKID's Avatar
Default Re: Need help with electrical problem for lighting (Mr.OB*GYN_Rhett)
first off, nice car, second, does anything strange happen when you turn the lights on?? any other thing turn on or off in the car, first i would check/replace the actual switch(the thing u turn to turn the lights on) forgot whats its called. check the relays, get a volt meter and try to trace and pin point where the voltage is going instead of the lights. third you might also have a short somewhere, the positive wire is coming in contact with a positive to something else.... maybe i am right, maybe i am comletely wrong haha but good luck hope u get it fixed u got a nice car
Old Oct 16, 2007 | 06:39 PM
superls92's Avatar
Default Re: Need help with electrical problem for lighting (coupeKID)
Did you check the fuse with a multimeter while it was plugged in with the lights on?? I would check and see if you have any voltage at the fuse. This should help you find out if the problem is before or after the fuse.
Old Oct 18, 2007 | 12:02 PM
sublimnal's Avatar
Default Re: Need help with electrical problem for lighting (superls92)
will do
Old Oct 18, 2007 | 03:59 PM
superls92's Avatar
feel free to im me if you have any other questions.
Old Oct 20, 2007 | 07:58 AM
thaonepointsixdb's Avatar
fuse....or bulb. i just fixed mine two days ago... replace the rear bulbs. one might be shorted out and it not visable at all.
Old Oct 20, 2007 | 11:55 AM
sublimnal's Avatar
Default Re: (thaonepointsixdb)
thanks i'll check it out
Old Oct 25, 2007 | 12:17 PM
sublimnal's Avatar
niceee
bumping it for the new smilies
Old Oct 25, 2007 | 12:24 PM
Naruto's Avatar
nothing that was suggested worked? I know when my wipers went all haywire ( it would automatically turn on themselves ), the issue was the actual switch. But then again, that's not the gauge lights
Old Oct 25, 2007 | 04:39 PM
sublimnal's Avatar
Default Re: Need help with electrical problem for lighting (Naruto)
Old Oct 25, 2007 | 05:04 PM
dubzz24's Avatar
Did you do what superls92 suggested? That was some good advice. Really not much point asking for more help until you try that.
On an off topic, years back my old 2000 Prelude blew a fuse and had the EXACT same symptoms.
sublimnal
Lighting
16
Oct 24, 2007 12:42 PM
sublimnal
Oct 12, 2007 07:09 PM
INTEGRAGATED
Jan 29, 2004 05:42 PM
wid326
Jan 9, 2004 02:13 PM
