???? B20 Head ????
Old Oct 13, 2007 | 11:56 PM
Coolero's Avatar
Default ???? B20 Head ????
heard about a b20 head called ... p8r head it suppossable has vtec values and i was wondering if there's anything like that or should i go kick someone ???
Old Oct 14, 2007 | 12:05 AM
SIC_jdm_da9's Avatar
next time search because there is alot about b20s but yes there is a b20 with a P8R head and it has vtec size intake i think valuse.... the best non vtec head out there.
Old Oct 14, 2007 | 12:21 AM
Coolero's Avatar
Default Re: (SIC_jdm_da9)
hey bro what year does that head come in ?
Old Oct 15, 2007 | 08:32 PM
B.J.'s Avatar
Default Re: ???? B20 Head ???? (Coolero)
Not sure if that true but it sounds wired
Old Oct 15, 2007 | 08:36 PM
LordAphotic's Avatar
most b20s out there have the head straight off the b18b... meaning they arent even matching the diameter of the bore.....
the head your talking about comes on the b20z. it has valves that are the size of the vtec ones off a b16 i believe... and the dome is the same size as the bore of the b20....
it obcourse flows much better... and will make any b20 much better.. obcourse it wont make it better than a vtec head would... but the main reason for that is those heads still flow better and since they change the cam profile in low and high rpms the power curve is smoother.
Old Oct 15, 2007 | 10:39 PM
Rapterboy0269's Avatar
Default Re: (LordAphotic)
Will a B20Z Head bolt onto a b18 block, i thought the head was slanted and the distributor was at a different angle?
Old Oct 15, 2007 | 11:34 PM
all wrong.... ok, b20z have LS heads also but there are b20b out there that have a p8r head... the CP is 9.2.1 and the p8r head will out flow some ported LS heads... you cant not put a p8r head on a LS block... like me i have a b20b 97 with a p8r head.
Old Oct 16, 2007 | 08:15 AM
MIMIC_INC's Avatar
sik jdm da......................thanks for the info i just learned something new..
so the p8r head makes the b20b run better as in faster or just overall feel....yea this question sounds wierd but i cant explain it .................
where can i get the p8r head (and would u be able to put vtec since its designed)
Old Oct 16, 2007 | 08:25 AM
nate_2k5's Avatar
Default Re: (MIMIC_INC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIMIC_INC &raquo;</TD></TR><TR><TD CLASS="quote">sik jdm da......................thanks for the info i just learned something new..
where can i get the p8r head (and would u be able to put vtec since its designed)</TD></TR></TABLE>
the head won't make a whole hell of a lot of difference stock for stock against a LS head, its more suited for if you are boosting or building a big NA non vtec build
it uses VTEC size valves but no you cannot "add" VTEC because thats an entirely different system that has nothing to do with valve size
Old Oct 23, 2007 | 11:04 PM
MIMIC_INC's Avatar
Default Re: (nate_2k5)
oOO ok i got it thanks.
gearhead818
Mar 21, 2010 07:48 PM
clevelee
Dec 3, 2008 11:53 PM
Coolero
Oct 15, 2007 05:43 AM
boostedek9
Mar 4, 2006 03:56 AM
ZedEx
Jul 19, 2005 01:30 PM
