Will this work???
Old Oct 13, 2007 | 11:07 AM
98GSR-Turbo's Avatar
Default Will this work???
Take crankshaft from an older b18a1 motor and put it in a 98 b18c1???? Will this work or not??? What is the difference between the cranks??
Old Oct 13, 2007 | 11:18 AM
doood's Avatar
been there done that
Default Re: Will this work??? (98GSR-Turbo)
gsr/itr crank = 87.2mm stroke
ls/b20 crank = 89mm stroke
if you want to use an ls/b20 crank you need to use ls/b20 length rods as well. it's an oem stroker of sorts.
read: https://honda-tech.com/zerothread?id=1837872
Old Oct 14, 2007 | 10:53 AM
so just get the rodsand crank and it would be BASICALLY the same as stock?
amios
Aug 19, 2009 02:56 PM
master honda tech
Apr 17, 2006 07:00 PM
jdm92teg
Apr 13, 2005 01:20 PM
hybridpatient95
20
Jan 4, 2005 05:07 PM
