94 ls question
Old Oct 14, 2007 | 02:27 PM
98ej8coupe's Avatar
Default 94 ls question
My neighbor has a 94 ls in his driveway he got for cheap because the person before him hit a curb doing aprox 15-20 mph. The drivers side front tire was pushed back to the fender and the only way the car is driveable is to put a donut on so it can turn. I looked at it today and nothing seems to be out of line (strut tower,strut) so i was thinking it could be the lca, but i was looking and it might be were the lca bolts to the frame and in that case im not gonna buy it..any suggestions/ help if that part would bend? thanks in advanced
Old Oct 14, 2007 | 04:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 94 ls question (98ej8coupe)
Yes, the frame can bend. Put the car in the air and inspect.
Old Oct 14, 2007 | 06:11 PM
98ej8coupe's Avatar
Default Re: 94 ls question (Dogginator)
yeah im hoping its not, im gonna take a better look tommorow, if it is wouldnt that be the sub frame?
Old Oct 14, 2007 | 11:27 PM
weaksonnn's Avatar
fixable
Old Oct 15, 2007 | 03:20 AM
98ej8coupe's Avatar
Default Re: 94 ls question (weaksonnn)
upp
Old Oct 15, 2007 | 03:34 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ej8coupe &raquo;</TD></TR><TR><TD CLASS="quote">yeah im hoping its not, im gonna take a better look tommorow, if it is wouldnt that be the sub frame?</TD></TR></TABLE>
Frame... subframe. Potāto... potato. The attachment points can be mangled.
Old Oct 15, 2007 | 06:24 AM
98ej8coupe's Avatar
hahah yeah im gonna take the suspension out and inspect the frame more closely
Old Oct 17, 2007 | 03:31 PM
98ej8coupe's Avatar
got the car today and took a look at it..everything is pushed back closer to the drivers door and the there is no noticable things being bent, i think were the front lca bolts to the cross member might be bent. any suggestions?
Old Oct 17, 2007 | 05:09 PM
weavertime1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ej8coupe &raquo;</TD></TR><TR><TD CLASS="quote">got the car today and took a look at it..everything is pushed back closer to the drivers door and the there is no noticable things being bent, i think were the front lca bolts to the cross member might be bent. any suggestions?</TD></TR></TABLE>
I have seen this quite a few times. Also, the whole cross member could be bent, which is no big deal really...hahahaha...if you have a garage with a lift. Look underneath where the LCA bolts to the cross member with three bolts towards the rear. Measure the distance on both sides from the back bushing bolt of the LCA to the body of the car under there. Thats usually where you can tell if they are bent. Goodluck!!!
Old Oct 17, 2007 | 05:34 PM
98ej8coupe's Avatar
Default Re: 94 ls question (weavertime1)
alright thanks man..lol i got no lift im gonna try to get under the car tommorow
Old Oct 17, 2007 | 11:11 PM
davidluko's Avatar
If you can get the car cheap and it's a nice car then don't let the curb damage stop you... the worse that could have happened is a bent subframe like mentioned, so check out the lower control arm (which is pretty much gauranteed to be bent after hitting a curb) and where it mounts onto the subframe. You might not even be able to tell right away that the subframe is bent until you get it all back together with a new control arm and see that it's still out of spec. You can get a subframe pretty cheap and replace it at home.
Old Oct 18, 2007 | 06:18 AM
Default Re: (Hatch_R)
I have seen the body of the car bent as well, so just look out for that as well!!!
Old Oct 18, 2007 | 08:32 AM
98ej8coupe's Avatar
Default Re: (weavertime1)
yeah i hope its nothing major like that i just cant notice anything that looks bent...i think the LCA would crack instead of bend.. the only thing i found was that the upper ball joint was pushed back and not sitting right..so im kind of stuck right now cuz i dont know what parts to order lol
Old Oct 18, 2007 | 09:26 AM
Default Re: (98ej8coupe)
I have a complete cradle...and I mean complete from a 96' integra SE (not that the model really matters for fittment). I pulled it off of one of the cars I parted out in case of something like this. Just so you know, I would let the whole thing including struts and front hubs, and upper ball joints too for $400 picked up. It is a very clean unit, which is why i removed it in the first place. This would have anything you could ever need from the front end suspension. Thanks!!!
Old Oct 18, 2007 | 10:26 AM
98ej8coupe's Avatar
alright man that setup comes with the cross member and lca's and everything?
Old Oct 18, 2007 | 11:24 AM
Absolutely everything..even the powersteering rack as well!! PM me if you end up needing it
Old Oct 18, 2007 | 12:12 PM
98ej8coupe's Avatar
alright man thanks alot for your help, im gonna take everything out this weekend and see whats up but ill deff let you know..thanks again
Old Oct 21, 2007 | 07:16 AM
98ej8coupe's Avatar
ripeed it apart yesterday and the LCA is pretty noticably bent now that i got under the car and looked at both of them..just orderd it so i should be good to go thanks for ur guys help!
ucantdrive4shit
Feb 27, 2005 06:27 AM
whitelsteg
Jan 20, 2004 01:38 PM
blackZC (W)
Feb 19, 2003 09:20 PM
crewjones
Dec 10, 2001 05:20 PM
