Cluster problem HELP
Old Oct 13, 2007 | 10:07 AM
DC2 R guy's Avatar
Default Cluster problem HELP
2001 ITR with a 98 jdm itr Cluster...
Problem is that my temp and turn signels is not working right...
Temps always stays on HOT...WHen turning on my singels the rpm/mph jumps up and down...
lmk if you can help
Old Oct 13, 2007 | 10:14 AM
BlueIntegraBoy's Avatar
Default Re: Cluster problem HELP (DC2 R guy)
I would suggest to you to swap the green film from the rear of the cluster or repin your cluster harness, but your immobilizer light will not work.
What I suggest is swapping the JDM ITR gauges (and swap the top center icon group) into your 01 cluster housing.
Follow these steps...
https://honda-tech.com/zerothread?id=1836281
If you have anymore questions, PM me.
EDIT: You can swap the 01 green film onto the 98 spec ITR cluster, but put the immobilizer icon group onto the 98 spec bezel and put the bulb behind where it's supposed to go. It should work.
Old Oct 13, 2007 | 10:21 AM
DC2 R guy's Avatar
Default Re: Cluster problem HELP (BlueIntegraBoy)
I dont have the 01 cluster
Canon Chhoun
Jan 22, 2019 06:51 PM
Downz
Jul 9, 2007 11:21 AM
GuitarSlinger78
Nov 14, 2006 10:56 AM
rev210k
Feb 2, 2006 03:41 PM
chads
Northwest (Sales)
Nov 29, 2005 04:42 PM
