HELP! overheating problem...
Old Oct 12, 2007 | 01:19 PM
kicksremix2o6's Avatar
Default HELP! overheating problem...
hey HT, im a noob here and i wanted to know what up with my teg. recently i been noticing that my car has been overheating when im idleing or im driving really slow. i changed my thermostat and it help a little bit. do you guys think its my head gasket? anyone experienced this?
Old Oct 12, 2007 | 02:01 PM
integraRS-T's Avatar
check ur dipstick if ur oil is milky in color ur gasket blew but it might be ur water pump
Old Oct 12, 2007 | 02:17 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Default Re: HELP! overheating problem... (kicksremix2o6)
Take your radiator cap off when the car is cold and let the car idle until regular running temp. Sometimes you can get airbubbles in your coolant lines/block/head and it will cause over heating.
Old Oct 12, 2007 | 02:43 PM
BMO98GSR's Avatar
see if your fan comes on
Old Oct 12, 2007 | 03:13 PM
hatchling37's Avatar
If you changed your t-stat, did you properly burp the system? It might just have been your thermostat and now you have an air pocket in your cooling system.
Old Oct 12, 2007 | 03:31 PM
Default Re: HELP! overheating problem... (hatchling37)
thanks for the advice guys! my fan works and my oil is not milky i will try burping it as soon as my car cools.
SIR EF9
Oct 27, 2012 10:34 AM
96_RHD_EK
21
May 1, 2008 08:11 AM
meanTheDope
Aug 22, 2005 10:31 AM
kg4h2l0
Oct 23, 2004 12:30 PM
Gabe_
12
Jun 13, 2003 02:47 AM
