type r LCA
Old Oct 12, 2007 | 05:11 AM
sin2o3's Avatar
* B A N N E D *
Default type r LCA
can those replace my stock ls LCA and do i need type r suspension for that because i have H&R springs
Old Oct 12, 2007 | 05:19 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: type r LCA (sin2o3)
ITR has different rear shocks and sway bar mounts.
Old Oct 12, 2007 | 05:30 AM
sin2o3's Avatar
* B A N N E D *
Default Re: type r LCA (Dogginator)
so your sayin the type r LCA is not compatible with my H&r springs or they are not interchangeable with the stock ls LCA
Old Oct 12, 2007 | 05:36 AM
Dogginator's Avatar
Daisy... Daisy...
The ITR shock mount to the LCA is different than your LS shock mount. The springs would work on ITR shocks.
Part 44 vs part 15.
Old Oct 12, 2007 | 05:41 AM
sin2o3's Avatar
* B A N N E D *
so what would i need to get if i wanted to put the type r LCA on my ls
Old Oct 12, 2007 | 06:23 AM
Dogginator's Avatar
Daisy... Daisy...
Rear shocks for an ITR.
Old Oct 22, 2007 | 05:10 AM
sin2o3's Avatar
* B A N N E D *
an itr shock would bolt on as a replacement of my ls shocks?
Old Oct 22, 2007 | 05:35 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Wow..
Lets make this easy, why do you even want to put Type-r LCA's on your car?
Unless you have busted ones, and you're getting a special deal,
or for some other unknown reason to us that seems to make sense?
If you really want to put the Type-r LCA's on, you need Type-r shocks, simple as that.
And yes, you can swap your springs right over to the Type-r ones.
Old Oct 22, 2007 | 06:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The only reason to use ITR rear LCA's is if you want to run a specific suspension setup that is only made for ITR's and not for non-R Integras.
gulftiresinc
Sep 25, 2005 09:45 AM
transitions
Jul 13, 2005 08:35 PM
jlv55
Nov 5, 2003 10:04 AM
ragejed
Feb 4, 2003 04:17 PM
AzN_Flava
Dec 12, 2002 05:54 PM
