steering wheel question???
Old Oct 15, 2007 | 01:35 PM
DeDonDeRosa's Avatar
Default steering wheel question???
ok when u guys put a no airbag steering wheel in your tegs how do u keep the SRS light from coming on. let me know thanks guys
Old Oct 15, 2007 | 02:37 PM
BlueIntegraBoy's Avatar
Default Re: steering wheel question??? (DeDonDeRosa)
Pull the bulb from the cluster or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">Dougster. Just go out and get/buy a plain 2ohm 5watt resistor. Maybe ratshack will cary it but i don't think so..
First take the plug from the air bag, cut it off. Strip the wires and solder the resistor from one wire to the other. Use some heat shrink tube over the exposed areas. Plug it in and your done. You might need to rest the srs system.
Jump the yellow plug that hooked to your fues box, it's plugged into a dummy connector . And take about three feet of wire so you can use it as a jumper wire.
Close the jumper wire turn the car onto ign (II), SRS light will go off, open the circut. SRS light will come on hold the wires again till the light goes off. It should flash 2 times. Turn the ign all the way off. Wait for 10 seconds. Then tuirn your car on... The light should now be off.
http://www.leedselect.com/parts-resistors.html sells the part for .50cent nugga.
https://honda-tech.com/zerothread?id=1899863
Old Oct 15, 2007 | 05:29 PM
samace_sg's Avatar
Default Re: steering wheel question??? (BlueIntegraBoy)
x2.. take the bulb out
anon191
Aug 11, 2013 06:05 AM
just_bn_me83
May 15, 2012 05:34 PM
bluelsvtecda9
Sep 18, 2010 10:17 PM
DeDonDeRosa
Dec 16, 2008 11:16 AM
4DRmafia
16
Oct 29, 2006 08:12 AM
