nitrous on a LS
Old Oct 12, 2007 | 09:05 PM
lsteg94's Avatar
Default nitrous on a LS
hey i have a 94 teg i had a question about runnin nitrous on it i jus got the stock block internals and everything i mena i have the E/H/I and **** but idk a safe shot to run on it..wet or dry??? i heard wet is better but just let me no prolly wen i do it though ill have stage 1 cams and thats it
Old Oct 12, 2007 | 11:42 PM
numberone's Avatar
Default Re: nitrous on a LS (lsteg94)
75 shot wet+proper tuning.
Old Oct 15, 2007 | 08:53 PM
B.J.'s Avatar
Notting will be safe with a stock block. wet is better but wharts your budget. Dont be a sally its going to blow sooner or later on the juice.
Old Oct 15, 2007 | 09:23 PM
St Jimmy's Avatar
* B A N N E D *
75-100 wet shot and you should be good
Old Oct 16, 2007 | 12:14 AM
VRD^sam's Avatar
Default Re: nitrous on a LS (St Jimmy)
i have a 55shot nx kit wet in my 193k BONE stock LS * no I/E/H* BONE stock spank gsr's all day
Old Oct 16, 2007 | 12:37 AM
Tornadom's Avatar
Holy lack of punctuation Batman!
Honestly, you need to do a lot more research on this subject before you attempt to make it work. Depending on the condition of your motor, as will be determined by: its oil consumption, mileage, compression readings across all 4 cylinders and leak-down test results, I would fathom a 40-60 shot is safe to run. Unless you have installed larger than stock injectors, a larger (or as a minimum, new OEM) fuel pump, and other fuel system upgrades (and undoubtedly the ECU tuning to match the upgrades), I would go with a wet system. If all else is in place, then a dry system would be fine as well.
98jdmek
Oct 31, 2007 12:06 AM
jdmjunkie8
Jul 18, 2007 02:11 PM
KHAN SHOP
Apr 1, 2007 12:28 AM
