Timing help
Old Apr 4, 2015 | 05:35 PM
potatointegra01's Avatar
Default Timing help
Well the head was recently off and didn't do timing marks. How do I time the engine when off it's a b18b
Old Apr 4, 2015 | 07:23 PM
B_Swapped93's Avatar
Default Re: Timing help
assuming the head is still off it's easy to see the piston at TDC, if the head is on drop a 12'' 3/8th extension down the plug well and spin it by hand till it's at it's highest point. then set the timing on the cams.
Old Apr 4, 2015 | 07:32 PM
rollinmyda's Avatar
Do you not have a lower timing belt cover, crank pulley, and cam gears? They have the timing marks on them...
Old Apr 6, 2015 | 01:17 PM
tamboo's Avatar
10 Year Member
yootoob is your friend:
https://www.youtube.com/results?sear...hanical+timing
Old Apr 6, 2015 | 05:48 PM
sh1ftey's Avatar
Should be able to easily line up the timing mark on the crank pulley.
TekBuDDy
Sep 21, 2018 03:28 AM
haas480
Mar 7, 2010 08:06 AM
Jap_Spec_Imports
Dec 20, 2007 06:15 PM
Danronian
Apr 12, 2006 03:06 PM
JediKGB
Dec 4, 2005 02:29 PM
