Corroded ECU
Old Apr 11, 2015 | 02:17 PM
Erika_ed8's Avatar
Icon3 Corroded ECU
Okay so I have a 1994 Acura Integra and every time I drive it she seems like she's losing power. As long as I'm ripping it though, the car drives fine.
At first I thought it was the dizzy because the Check engine light was on and a code for the cylinder position sensor was being throne. But then I read that it could also be the ECU if it got wet. Only thing is, there was no sign of it being wet or even a little bit of moisture.. but it was corroded on the one side but not by where the harness plugs in. idk what else to do .... HELP !!!
Main Concern:
Car is losing power and misfiring
Old Apr 11, 2015 | 09:44 PM
MotorMouth93's Avatar
10 Year Member
Default Re: Corroded ECU
This may seem obvious....but you did check the cylinder position sensor didn't you?
Old Apr 13, 2015 | 04:36 AM
Erika_ed8's Avatar
I read that the sensor is in the dizzy itself, so I just changed the dizzy as a whole. So could it be the timing or something ? or the dizzy isn't in right ?
Milby90ls
Sep 10, 2011 09:13 AM
aaronpark
Sep 24, 2009 12:49 PM
crxmadness
Sep 21, 2006 12:43 PM
incognitoracerr
Jan 11, 2004 07:13 PM
CivicHB91
Jan 22, 2003 03:31 PM
