b18b1 valves problems
Old Apr 4, 2015 | 11:07 PM
96 acura's Avatar
Default b18b1 valves problems
i put a new head gasket on, so tried to start the car nothing so i have fuel and spark timing is dead on so i check the valves i have something not right, the exhaust side is fine its the intake side, so i loosen the adjustment screw and nothing you cant get the feeler gauge in there at all so i switch the rockers from the exhaust side to the intake side and same stuff cant get a feeler gauge, and there is not compression intell i loosen the cam caps bolt then i have compression
Old Apr 5, 2015 | 04:27 PM
96 acura's Avatar
Default Re: b18b1 valves problems
anyone please ideas ill try anything
Old Apr 5, 2015 | 05:30 PM
B_Swapped93's Avatar
your timing is off it has nothing to do with lash, set the mechanical timing correctly
Old Apr 5, 2015 | 05:34 PM
F1_Racer's Avatar
Your valves are not closing in the correct position.
Old Apr 5, 2015 | 05:41 PM
96 acura's Avatar
how do I make sure that the closing in the correct position
Old Apr 5, 2015 | 06:05 PM
setting the engines timing... smh easiest way drop a 12'' 3/8th drive extension down the #1 plug well and spin the engine via the crank pulley. then when the extension is at it's highest point set the cams to TDC why would you try something that's clearly above your skill level, you could have research the task first to learn how to properly do it.
Old Apr 5, 2015 | 06:54 PM
96 acura's Avatar
About my skill level well you never learn if you dont try n i used zip ties to hold the cams to the belt so, sorry for asking questions i well fine a different site to use
Old Apr 6, 2015 | 09:07 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Onto the actual post though.. Double check your timing, make sure your crank is TDC along with the cams.
And instead of switching the rockers around, you need to adjust the lash since they're out of place.
INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm)
EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm)
All you need is your feeler gauge, 12mm wrench, and a screwdriver to adjust the b18b1 head.
Old Apr 6, 2015 | 10:00 AM
tamboo's Avatar
10 Year Member
never hurts to look it up on yootoob:
https://www.youtube.com/results?sear...hanical+timing
Old Apr 6, 2015 | 11:46 AM
96 acura's Avatar
Thank you cleanjdm are the up arrows going to be up cause the arrows in the middle dont line up, the ex an in cam both seem to be a booth off
Old Apr 6, 2015 | 05:30 PM
96 acura's Avatar
So i did the timing went to start it and a big boom i dont see any damage but i have no clue why it did that
Old Apr 6, 2015 | 05:36 PM
96 acura's Avatar
exhaust back fire
Old Apr 6, 2015 | 06:37 PM
Hype-R Stalker
Originally Posted by 96 acura
exhaust back fire
Most likely off time if you're getting a backfire, they can't even be one tooth off.
When everything is TDC, you should see lines 3 and 9 oclock on your cam gears that also line up.
Old Apr 6, 2015 | 09:54 PM
96 acura's Avatar
Is there a way for me to post pics, i made damn sure its on, how could i know my cams are the right way or is there only one what you can put the on
Old Apr 7, 2015 | 10:11 AM
96 acura's Avatar
Ok so i line up the crank to tdc and cams to tdc so i crank it over nothing i check the tdc marks again the the crank is at tdc the cams are 180 or up sidedown, i dont get why would the cams be tdc but not turning with the crank, cams an crank are line up right when i try and start it , nothing re check and cams are off
Old Apr 7, 2015 | 03:10 PM
fcm's Avatar
fcm
Old Fart
If mechanical timing is "moving" after you have set it, either timing belt is N/G or timing belt tensioner is N/G.
Once you set the timing are you cranking engine by hand, [crank pulley] to make sure nothing is binding or cams gears are not skipping ? 94
Old Apr 7, 2015 | 04:56 PM
96 acura's Avatar
it seems to turn ok but then get hard, ill check and make sure nothing is binding and its a newer belt n the belt seems nice and tight
Old Apr 7, 2015 | 06:10 PM
Hype-R Stalker
Did you tighten the tensioner correctly so it didn't go off a tooth there?
And did you end up fixing your valve lash once you got the timing somewhat straight?
Old Apr 7, 2015 | 07:24 PM
96 acura's Avatar
ok the timing is great! i was trying the crank and its hard so i look up top again it the valve lash, the intake cam is tight like you can not get a feeler gauge in there and the rocker are as low as they can go this is the problem
Old Apr 7, 2015 | 07:27 PM
96 acura's Avatar
i did not touch the tensioner, i lay down one cam then i sliped the belt over the other one sorry very bad speller
Old Apr 7, 2015 | 09:28 PM
Hype-R Stalker
If you can't fit a feeler gauge in there, you might need to adjust your valve lash.
Old Apr 7, 2015 | 10:09 PM
96 acura's Avatar
the valve lash is the screw right 12 mm and a flat head? i did that it all the way down
Old Apr 8, 2015 | 07:49 AM
96 acura's Avatar
im going to take the head back off going to go though everything again, making sure all my valves are ok
Old Apr 8, 2015 | 01:14 PM
96 acura's Avatar
after seating new valves the valve stem length is too high i think that's my problems how do i deal with this
Old Apr 8, 2015 | 08:01 PM
96 acura's Avatar
took the head off everything is fine so it come back to the valves is it ok to take some off the top of the like .006?
