Low compression test question
Old Apr 12, 2015 | 06:24 PM
97integraa's Avatar
Default Low compression test question
Hey guys I'm new here but I have a question I have a 97 integra b18b1 with low compression all cylinders were at 109 any ideas what it could be bad valve seals or rings it does burn oil about a quart every 600 miles I have 190000 miles on it
Old Apr 14, 2015 | 08:10 AM
MotorMouth93's Avatar
10 Year Member
Default Re: Low compression test question
Do both a wet and dry compression test. If the numbers are the same it could indicate that your valve seals are bad. If the wet test numbers are higher it implies that the piston rings are the problem and doesn't say anything about the valve seals.
Old Apr 16, 2015 | 11:25 PM
nicknack25's Avatar
x2.
Also, if it is your seals, you will notice a lot of blueish smoke at cold start ups.
ewilliams1990
Jun 28, 2014 03:44 AM
boost fed ls
Sep 2, 2004 05:19 PM
Sport_Injected
Aug 25, 2004 09:21 PM
DANG YO
Nov 24, 2003 04:26 AM
EF8_SiR
Jul 20, 2003 10:24 PM
