throwing code 13? jumpy idle. please help
Old Apr 16, 2015 | 02:38 PM
rjmteggy's Avatar
Default throwing code 13? jumpy idle. please help
Ok so I bought a 1990 Integra. The idle is jumpy and my ecu is reading code 13 (barometric pressure) Wtf do I do to fix it
Old Apr 16, 2015 | 03:02 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: throwing code 13? jumpy idle. please help
I think you may need a new ECU but try a good working MAP sensor first and reset the ECU.
Old Apr 16, 2015 | 04:15 PM
rjmteggy's Avatar
Ok I'm buying a new (used) ecu. Tomorrow. Any tips on putting it in?
Also any way to tell what model my Integra is?
Old Apr 16, 2015 | 09:06 PM
SpokaneSpeed's Avatar
Pretty basic, disconnect the negative battery terminal, unbolt the 10mm ecu hold down bolts, unplug the old ecu, plug in the new ecu, bolt it back down, and reconnect the negative. Done.
Old Apr 16, 2015 | 09:49 PM
nicknack25's Avatar
There is a barometric sensor kinda near the ecu. My friend has this issue and has had it for about a year or 2 lol. He doesn't really care i guess. We swapped out the sensor and ecu but his never went away. His wiring is all messed up though so don't worry about that. If the ecu doesn't work, try swapping the sensor.
Old Apr 16, 2015 | 10:19 PM
In the obd1 ecus the barometric pressure sensor is within the ecu. I don't recall the obd0 cars having an external barometric pressure sensor... it should also be within the ecu...
nicknick25, where was this located and what did it look like? I think you may be confusing this sensor with another...
frankenghia
Dec 10, 2011 08:43 AM
Hgoku10
Aug 4, 2009 09:05 AM
Sumslapper
Jul 6, 2007 11:21 AM
crxhf19
Sep 13, 2005 04:46 PM
kim_2_da_chee
May 30, 2003 06:18 PM
