HELP!! parking light issue
Old May 17, 2015 | 12:31 PM
98dxkoupe's Avatar
Default HELP!! parking light issue
I have 2001 gsr having a front passenger side parking light issue driver side works fine both front signals work properly but not parking light on passenger side tried replacing bulbs anyone have this problem or could point me in the right direction?
Also if fuses were blown would one side work and not the other maybe relay? Not a clue HELP!!
Old May 17, 2015 | 06:16 PM
RepumIntegra's Avatar
Default Re: HELP!! parking light issue
Loose wire/ wire not making connection.
Old May 17, 2015 | 07:22 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try poping out the bulb and putting it back in a few times, this used to happen to me sometimes when i would pull out my corner signal lights then when i would put it in the light doesnt stay on like it should but the signal will work but once the signal is turned off the light goes off as well, never figured it out i just would play with the bulb then it would stay on.
Old May 18, 2015 | 01:54 AM
98dxkoupe's Avatar
Ill try it im gonna trace my passenger side signal parking light wire see if there is a short or a loose connection thanks for the input
98dxkoupe
Lighting
15
Oct 12, 2015 05:33 AM
Cashmoney061596
Nov 5, 2013 05:49 PM
integraracing91
Dec 3, 2006 03:43 PM
vthree
May 6, 2006 03:56 PM
upstate
Jul 21, 2004 12:46 PM
