91 integra Electric problems
Old Apr 6, 2015 | 03:08 PM
Russian21's Avatar
Default 91 integra Electric problems
My battery keeps dying. I bought a new battery 2 weeks ago with a new alternator. But it still dies out in a week. I've checked to see if there's something that drains it while off but didn't find anything. What could be the problem?
Old Apr 7, 2015 | 05:23 AM
TheRealTegger's Avatar
Default Re: 91 integra Electric problems
Get a cheap digital multimeter and check the DC voltage between the battery terminals with the engine running. You should see between about 13.8V and 14.4V.
If you see 12.65V or less with the engine running, then your alternator is not charging.
Old Apr 7, 2015 | 03:28 PM
fcm's Avatar
fcm
Old Fart
How did you test for a drain, did you do a proper parasitic drain test?
When you say the batt. drains in a week, do you mean when just parked or even if you run the car? 94
Old Apr 13, 2015 | 03:19 AM
Russian21's Avatar
I have tested and it reads at 14.15V.
Old Apr 13, 2015 | 03:22 AM
Russian21's Avatar
To test the drain I used a multimeter and check various wires. I drive it daily and I goes out in about a week. since the last time it happened surprisingly it's been 2 1/2 weeks.
Old Apr 14, 2015 | 03:56 PM
fcm's Avatar
fcm
Old Fart
Either the alt. or voltage reg. is bad, have the system tested at a batt./alt. shop, most will do it for free. 94
DA9_JDM_408
Mar 7, 2013 10:51 AM
Fall_out_boy_99
Jun 19, 2010 07:00 PM
VTEC_Du_Ma_Mai
Mar 20, 2008 04:48 PM
Byaaah!
Jan 30, 2007 12:06 AM
manyakiexpi
Nov 14, 2006 10:20 AM
