RPMs
Old Nov 6, 2008 | 03:29 PM
Lucman's Avatar
Default RPMs
Hi everybody Im having some trouble with my car, the RPMs are low, they are a lil bit less than half. Any tips on how to fix this. TIA
Old Nov 6, 2008 | 04:00 PM
Lucman's Avatar
Default Re: RPMs (Lucman)
Forgot to mention that its a 95 integra
Old Nov 6, 2008 | 04:27 PM
letsdrive's Avatar
your question makes no sense. be more specific! do you mean the car idles low?
Old Nov 6, 2008 | 07:18 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (letsdrive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letsdrive &raquo;</TD></TR><TR><TD CLASS="quote">your question makes no sense. be more specific! do you mean the car idles low?</TD></TR></TABLE>
True.
Does it do it when its cold/warm?
Old Nov 7, 2008 | 02:48 PM
Lucman's Avatar
Default Re: (Byaaah!)
Sorry about that but I dont know much about cars. yes it idles low and it does it when its warm.
Old Nov 7, 2008 | 06:33 PM
Byaaah!'s Avatar
Default Re: (Lucman)
Has your battery light came on?
Old Nov 7, 2008 | 09:51 PM
Lucman's Avatar
Nope battery its ok in fact I changed it bout a year ago.
Old Nov 7, 2008 | 10:35 PM
lmike6453's Avatar
How low? And does it fluctuate?
Old Nov 8, 2008 | 12:43 PM
Lucman's Avatar
Default Re: (lmike6453)
The following pic is when I first turn on the car......
This second pic is when the car is warm..... Hope that helps/explains more.
Old Nov 8, 2008 | 12:52 PM
projectTeG's Avatar
thats normal
Old Nov 8, 2008 | 01:14 PM
Lucman's Avatar
Default Re: (projectTeG)
Really? isn't suppose to be right on the number one?
Old Nov 8, 2008 | 01:24 PM
allmotadb8's Avatar
i believe normal is at 800 + or- 50, which is what you're at. Correct me if im wrong.
lmike6453's Avatar
750 +/- 50 at normal temperature.
Old Nov 8, 2008 | 03:11 PM
Lucman's Avatar
so im ok @750+, But is there a way to fix this?
Old Nov 8, 2008 | 03:21 PM
ThatGreenGsr's Avatar
what??? you're fine at that rpm there is nothing to fix. are you asking is there a way to adjust your rpm?
Old Nov 8, 2008 | 03:28 PM
Lucman's Avatar
Default Re: (ThatGreenGsr)
yes thats what I meant... sorry
Old Nov 8, 2008 | 03:44 PM
dc4b20's Avatar
you cant fix something that isnt broke. it is fine, leave it alone.
Old Nov 8, 2008 | 03:48 PM
shnukems1's Avatar
haha, this gave me a nice laugh
Old Nov 8, 2008 | 03:57 PM
then youre answer is yes you can adjust it. but there is no reason to change it youre fine dont worry
Old Nov 8, 2008 | 04:30 PM
Lucman's Avatar
Ok cool, thanks for all the help everyone.
Old Nov 9, 2008 | 11:42 AM
lmike6453's Avatar
Np, there is an idle adjuster screw on the back underside, kind of, of the intake manifold in case you really need to adjust.
Old Nov 9, 2008 | 01:51 PM
itr#1334's Avatar
lol
Old Nov 9, 2008 | 02:56 PM
Tegraracer90's Avatar
Default Re: (itr#1334)
READ OWNERS MANUAL....it tells you what the warm and cold idle rpm is.....
its normal
Old Nov 9, 2008 | 03:59 PM
TenaciousB18c1's Avatar
Default Re: (Tegraracer90)
you should probably take your car to have the oil changed and turn off the maintenance light unless you're feeling adventurous enough to learn how to turn it off yourself. (push and hold he button under the dash)
FTNW
22
Jul 15, 2011 09:28 AM
jdm_kingz
Jan 10, 2008 03:57 PM
MR_EJ8
30
May 28, 2007 01:31 AM
HTn00b
18
Jan 30, 2007 11:16 AM
JAMinCiViC
Jul 3, 2005 08:54 PM
