SRS?
Old Nov 9, 2008 | 12:20 AM
Zero Signal's Avatar
Default SRS?
When they do state inspection is the srs included or is it independent from the ecu basically the airbags being a visual inspection or will it throw a code and fail, it's a 2000 teg?
Old Nov 9, 2008 | 01:40 AM
BlueIntegraBoy's Avatar
Default Re: SRS? (Zero Signal)
SRS has its own ECU behind the center dash console. If there's a malfunction in the system, it will throw a red SRS light (on the cluster) when your car is turned on.
Old Nov 9, 2008 | 11:35 AM
So if you take out the SRS control unit will the SRS light go off and when you go to get your car inspected when the plug the thing in will they be able to tell?
Old Nov 9, 2008 | 11:46 AM
sh4mr0ck's Avatar
Default Re: (Zero Signal)
Is your SRS light on? You can jump it from below the passenger side of the dash... I had to do it before when I pulled all my fuses and changed them all...
It's fairly simple and theres a write up around here somewhere...
Old Nov 10, 2008 | 01:38 AM
If you take both air bags and the control unit out will the light be on and will the be able to tell at inspection other than the visual?
Old Nov 10, 2008 | 01:18 PM
bump
Old Nov 10, 2008 | 02:55 PM
TunerN00b's Avatar
Why are trying to illegally pass an inspection?
Old Nov 10, 2008 | 04:16 PM
ttt
Old Nov 10, 2008 | 04:23 PM
bigdogadam's Avatar
if you take both airbags out it certainly won't pass inspection. in MD you aren't allowed to remove any of your cars factory safety standards. however that MAY be different where you are located but i highly doubt it
Old Nov 10, 2008 | 07:40 PM
I will put the passenger and wheel air bags back in for visual inspection but the unit will not be there I am just wondering if when they do the obd2 testing if it will show up when they plug it up
Old Nov 11, 2008 | 09:06 AM
NCteggy's Avatar
you will still pass if its on. they dont check for the srs light its not required. i had one on and was able to get mine inspected with no prob.
Old Nov 11, 2008 | 10:29 AM
sweet thanks
JAYDEMEM
Honda Civic (2001 - 2005)
Nov 18, 2008 12:41 PM
mexicovi1la
Aug 10, 2005 09:43 AM
mongoliandonuts
Feb 21, 2005 08:37 PM
StoneGold
Dec 8, 2004 11:24 AM
94_del_sol
Nov 15, 2004 10:10 PM
