LS-V question
Old Nov 12, 2008 | 10:16 AM
d_EG COUPE's Avatar
Default LS-V question
im having this problem where vtec only cracks some times. like sometimes it will crack then the next i try to take it down 8.5 theres no vtec. and then it'll be like that for a while. and i have no check engine light either. so i was wondering could it be the dizzy?
Old Nov 12, 2008 | 10:29 AM
neardon's Avatar
I'm a Jackass
Default Re: LS-V question (d_EG COUPE)
No its not the distributor. Hows your oil level? When was the last time you changed it? Have you cleaned the screen on your vtec solinoid? What type of ecu/program are you running? What is your ls/v setup?
Old Nov 12, 2008 | 10:37 AM
d_EG COUPE's Avatar
Default Re: LS-V question (neardon)
my oil pressure sit at 60. i just did a oil changed 4 days ago. no i havent cleaned the screen on the solinoid. s100 just a stock setup.
Old Nov 12, 2008 | 10:53 AM
neardon's Avatar
I'm a Jackass
Did you use a gsr or b16 head? Do you have any mods/bolt ons? Did you use a golden eagle kit or similar? Is the s100 just straight from hondata no dyno time?
Old Nov 12, 2008 | 10:55 AM
d_EG COUPE's Avatar
uhm b16 head. just header for now. no didnt use any kit. and no the s100 is from a friend i bought it from. Could it be the ecu???
Old Nov 12, 2008 | 11:00 AM
neardon's Avatar
I'm a Jackass
Well if you didn't use a golden eagle kit, what did you do for your oil line? Without the extra oil line there is pretty much no chance of vtec crossing over. It could also be how the ecu is programmed.
Old Nov 12, 2008 | 11:13 AM
d_EG COUPE's Avatar
i had my head tapped already. i just had a machine shop do it a long time ago. and i do have the extra oil line in
Old Nov 12, 2008 | 11:30 AM
dc4b20's Avatar
try and use another vtec ecu and go from there. process of elimination. check the screen on the vtec solenoid. how did you wire up the vtec solenoid?
Old Nov 12, 2008 | 11:37 AM
d_EG COUPE's Avatar
Default Re: LS-V question (dc4b20)
16 gauge wire from solenoid to A4 on the ecu
Old Nov 12, 2008 | 02:55 PM
HONDRETTI's Avatar
if your vtec works SOMETIMES i dont think its a mechanical problem bc it still works. if your oil pressure is okay and your speedometer works youre fine. i would check the wiring to your ECU, make sure your connections are snug.
Old Nov 14, 2008 | 08:47 AM
d_EG COUPE's Avatar
It was the solenoid!!!! ding ding ding!!! thanx guys! i dont knoe wat id do with out white people i mean ht
Built4Battle
Oct 20, 2011 12:18 PM
AJxr
Jul 27, 2009 02:27 PM
ivan93egreppin210
Jun 11, 2008 12:04 PM
lsvtec1.9lcrx
17
Dec 15, 2005 04:47 PM
jade butterfly
Jul 16, 2005 05:45 PM
