Need help on radiator plz!!
Old Nov 6, 2008 | 07:26 PM
Frankie_Nguyen's Avatar
Default Need help on radiator plz!!
i have an 90 integra rs and my radiator seems like it does not work. the top tube is hot but the lower tube is cold. what is wrong with it?
Old Nov 6, 2008 | 07:30 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: Need help on radiator plz!! (Frankie_Nguyen)
Could be thermostat, clogged radiator, water pump.
Does it overheat?
Old Nov 6, 2008 | 08:28 PM
FULLYBUILT2.0's Avatar
should be your thermostat...your car should be over heating then right???.....if you are having back pressure in your reservoir tank then it should be your water pump!!!!u might want to fix that cause your motor could BLOW...
Ty h2b eg
Jan 7, 2018 12:23 PM
integraNooB
Jan 15, 2008 06:19 AM
tbonez
Feb 9, 2007 05:53 AM
projectM
17
Feb 14, 2003 12:53 AM
