b18b1 idle problem
Old Nov 6, 2008 | 07:31 PM
COBRA_ROCKS's Avatar
Default b18b1 idle problem
when i cold start my car...the rpm gauge goes up and quickly goes back down to zero and my car simply dies...the problem keeps occurring constantly unless i keep my foot on the gas pedal...or til the engine is warm up but still it keeps idling at 500 rpm only...iwhen i turn on the headlights..the engine seems as if its gonna die off and when i turn off the lights...the idling barely climbs back up to 500 rpm...what is the cause of this? how do i diagnose this problem... i have a 1998 hatchback with a b18b1 motorand im using a b16 tranny...
Old Nov 6, 2008 | 07:39 PM
b20vtech's Avatar
Default Re: b18b1 idle problem (COBRA_ROCKS)
Welcome to the board!!
try checking ur TPS voltage to see if it's in the correct position. it has to be about .5v on close throttle and about 4.5v on wot....
Old Nov 6, 2008 | 07:50 PM
Default Re: b18b1 idle problem (b20vtech)
the thing is the distributor that came with the car when i bought it is a dx distributor..do yoiu think if that's the problem? should i get a ls distributor?
Old Nov 6, 2008 | 07:54 PM
b20vtech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COBRA_ROCKS &raquo;</TD></TR><TR><TD CLASS="quote">the thing is the distributor that came with the car when i bought it is a dx distributor..do yoiu think if that's the problem? should i get a ls distributor?</TD></TR></TABLE>
what the PHO?? A dx dizzy on an LS head? first time ive herd of that! must Be one ghetto swap u got there! Yes i would deffinately change the distributor out to a LS one. BTW i have an OBD2 LS distributor for sale PM me for more info.
Old Nov 6, 2008 | 10:09 PM
racebum's Avatar
timing not happening where it should will absolutely cause this condition. how many degrees BTDC are you getting spark?
Old Nov 7, 2008 | 10:13 AM
Default Re: b18b1 idle problem (idrivesideways)
how much you want for the obd2 distributor?
91EX4dr
Dec 6, 2008 06:30 PM
drummr6
Mar 17, 2007 04:10 PM
Aphelion
Feb 26, 2005 07:41 AM
BDiddy
Jan 10, 2003 06:50 AM
