Dying Problem
Old Nov 10, 2008 | 08:33 AM
keeblar's Avatar
Default Dying Problem
Hey guys I wanted to know if you guys can give me some info.
I got my 95 Gsr about 3 months ago.
The motor runs strong and I had no problem buying it with the minor problem it came with.
When I run the car pretty hard it will shut down after you are coming to a dead stop.
It will just Die and then When I start it back up I have to hold down the gas and turn the key at the sametime just to get it started( Other wise I just get a crank over and no start). I was thinking that the timing is off on it and needs to get ajusted because of the hard start up..
The car idles fine but it is just when you have to turn it back on when it sounds like if you are trying to push out to extra fuel just to get it started...
Also this happen to me twice already...
When I am Pushing it on the freeway the car will out of nowhere bog down and start losing power and then it will kick back on after it has its moments.
It does not happen all the time it was just those to moments that it did it.
Is this part of the timing also ?
A bad dizzy ???
timing?
Can you guys get back to me asap I would like to find this stuff out so I can fix it before my other bills kick in =-P
Old Nov 10, 2008 | 09:29 AM
AWD Terror's Avatar
Default Re: Dying Problem (keeblar)
Well when it shuts down after you stop, sounds like fuel related. Especially since you need to hold the gas to the floor for it to start. I'm guessing you see a big cloud of black smoke when it fires again.
Check your exhaust. This hapened to me once, and the cat was clogged.
Old Nov 10, 2008 | 01:14 PM
j_bizach's Avatar
Default Re: Dying Problem (AWD Terror)
Check your fuel filter
Old Nov 11, 2008 | 08:40 AM
keeblar's Avatar
Default Re: Dying Problem (j_bizach)
well there is no Cloud of anything that is it..
Also I was thinking about the cat or O2 because the car breaths if you hold down the Gas pedel alittle.
GSR15
Aug 12, 2007 12:39 AM
solofthesouth
Apr 9, 2006 06:52 PM
BigD+Itsuki
Jun 21, 2002 11:40 AM
