1990 da9
Old Nov 12, 2008 | 09:22 PM
droopyli05's Avatar
Default 1990 da9
i had my integra swapped with a b16a out of a 92-95 del sol 170 hp version and converted my teg to obd1. my vtec use to kick in but now it doesnt...... but also the check engine light has always stayed on im running a pr3 obd1 ecu the only sensor im missing is a knock sensor and the ecu is not even throwing that code.... its throwing eod, iat, and o2 sensor it was throwing vss but got that fixed still no vtec kick and the im just trying to figure out what i need to do because im ready to give up on this car it has had these problems since the day i brought it back from the shop. oh and the coolant fan works but wont kick on by itself plus when i did rig it up to work the car still over heats i changed the thermostat as well and found some gunk didnt know what to make of it though. please somebody help me
Old Nov 13, 2008 | 06:36 AM
neardon's Avatar
I'm a Jackass
Default Re: 1990 da9 (droopyli05)
The vss will make vtec to turn on, have you reset your ecu since you fixed the problem? Does your sepdo work? Is your oil full and in good condition?
droopyli05
16
Nov 15, 2008 02:36 PM
music462
Aug 31, 2008 06:12 PM
vtecpsyco
Oct 23, 2005 11:18 PM
Boost2NA
Sep 14, 2004 02:44 PM
Kamin
Jan 18, 2002 05:47 PM
