Battery Tie Down Question
Old Nov 6, 2008 | 10:04 PM
lmike6453's Avatar
Default Battery Tie Down Question
I bought my car without a battery tie down and was told it is very important to have a tie down so that the plates inside the battery do not shift and short it. Also, so the positive lead does not touch the fuel filter. Is this true?
Also, I was looking to buy J hooks at Autozone but they only had 8 and 10 inch ones. 8 inch seems too short when measuring, and 10 inch will pop through the hood. In this diagram, how long is part number 3?
Old Nov 7, 2008 | 09:03 AM
lmike6453's Avatar
bump
Old Nov 7, 2008 | 09:57 AM
steveharrmr23's Avatar
Default Re: Battery Tie Down Question (lmike6453)
pmed about parts 3/2/20
Old Nov 7, 2008 | 10:30 AM
thewrai6th's Avatar
Default Re: Battery Tie Down Question (steveharrmr23)
Get the 10" ones and bend them to your liking.
It is important to have a battery tie down so that in the event of an acident, the battery is less likely to short and catch the car on fire. On top of that, you don't want it bouncing around in the engine compartment.
Old Nov 7, 2008 | 11:02 AM
twentyhurtz's Avatar
Default Re: Battery Tie Down Question (thewrai6th)
my battery tie down brace, litterally rotted, replacing with an oem one is expensive unless you get one free from a junk yard, i went to Lowes and bought a 3ft stick of flat aluminum bar and just cut it to desired length, drilled holes, instant tie down bar, works great, but i have no suggestion for making a j-hook
Old Nov 7, 2008 | 02:13 PM
lmike6453's Avatar
Thanks for the input, but I do not want to bend or cut them in case i ever need to take the wing nuts off of the j hook.
Old Nov 7, 2008 | 06:56 PM
INTEGRA LVR's Avatar
i bought mine at auto zone comes with 2 j hooks the tie down itself 2 rubber bushings and wing nuts it work out great for me
plus its under five dollars
Old Nov 7, 2008 | 08:35 PM
94VTEC2TONE's Avatar
autozone, junkyard or whatever is a good idea. and yes from vibrations you will eventually ruin the plates in the battery and be forced to get a new one
Old Nov 7, 2008 | 10:22 PM
lmike6453's Avatar
Default Re: (INTEGRA LVR)
Did you buy the 8 inch ones or 10 inch ones?
Old Nov 8, 2008 | 11:31 AM
BMXman's Avatar
Default Re: (lmike6453)
I cut mine and they thread on and off just fine...don't worry about it.
Old Nov 8, 2008 | 05:22 PM
dc2long's Avatar
Default Re: (BMXman)
i cut mine also. they work fine
Old Nov 9, 2008 | 11:40 AM
lmike6453's Avatar
With a dremel?
Old Nov 9, 2008 | 08:05 PM
dc2long's Avatar
yeah i cut it with a dremel
Turbo_Mike
Apr 30, 2006 06:25 AM
Acura EL
Aug 10, 2004 02:01 PM
RTW DC2R
May 14, 2003 12:26 PM
crashtest Sonny
Oct 8, 2002 05:43 AM
