motor mounts question
Old Nov 6, 2008 | 09:53 PM
PowerLeg's Avatar
Default motor mounts question
i have a jrsc on my LS and i also have avid motor mounts the mounts are solid metal ones
is my car suppose to vibrate and drone tremendously in the cabin?
also my idle is like at 500 i think, seems lower then normal but doesn't bother me. just wonder if it is normal.
Modified by PowerLeg at 11:24 PM 11/6/2008
Old Nov 6, 2008 | 10:11 PM
lmike6453's Avatar
At warm temp, idle should be 750 +/- 50. Is your temp gauge 4/9 full?
Harder types of rubber or polyutherane in motor mounts will make the dash and interior by it vibrate like crazy. That was the only reason why I took my motor mount inserts out.
Old Nov 6, 2008 | 10:16 PM
racebum's Avatar
Default Re: (lmike6453)
i have no vibration issues with the energy mounts. i also have a motor that has been gram balanced within half a gram so i might not be the best guy to ask about vibration. i've never tried them on a stock engine but i will say they are a wonderful way to keep your stock mounts alive if you drive hard. i have no idea how people do that rear engine mount. is is just a ***** with the engine out let alone with everything in the way.
PowerLeg's Avatar
ok just trying to clear up
i'll also check again on the idle tomorrow
thanks
temp gauge is around 4/9 yea
do you guys get a drone with solid mounts?
its a dc header with a stock itr cat back btw. it should definitely not drone in cabin, unless the solid mounts themself are the cause of the cabin drone
confirm please - thanks
Modified by PowerLeg at 11:26 PM 11/6/2008
attica
13
Feb 17, 2010 08:23 PM
smokey.23
22
Mar 24, 2009 09:01 PM
Knightmare69
10
Sep 25, 2006 12:56 PM
fw190bvi
Jan 22, 2006 10:50 AM
ID_ten_T
Sep 19, 2004 12:26 PM
