DA swap help?
Old Nov 11, 2008 | 05:20 PM
90tegblueonblack's Avatar
Default DA swap help?
currently restoring a 90 gs, Body is just about done, interior is a mess though, still searching for some missing parts at the moment
Bought a GSR longblock.
I am using my ls transmission
Do i use a clutch/pressureplate/flywheel/ for a gsr? or an ls?
And other question is, i was going to purchase an obd0-obd1 conversion harness use my p28 chipped, with an aftermarket intake.
What should i do about the distrubutor? Some say cut the extra leg use my obd0, some say swap dizzy internals from my obdo to the gsr.
Does the obd0-obd1 conversion harness allow a direct plug in to the gsr distributor so i wouldnt have to do these things
getting it from rywire or kingmotorsports?
would really appreciate the help so i can do the drop
Old Nov 12, 2008 | 08:33 AM
Default Re: DA swap help? (90tegblueonblack)
ANYBODY?
Old Nov 12, 2008 | 09:09 AM
LetsGetSerious's Avatar
Not that Im any help, but whats up to another Ohio DA.
super jdm yo's Avatar
sounds like you got a lot a head of you... but i'll try to help with what i know.
so for the clutch, it'll depend on the transmission you're using. and since you say ls, i'm guessing it's the original one from the car. so you'll need to get a clutch kit for any 90-91 b series. the difference is the teeth count 90-91 is different from 92+
i think the distributor is going to depend on what wiring harness you are going to be using. i think the best bet would be to get a complete gsr intake manifold with the wiring, a gsr distributor, and then get the obd0-obd1 jumper harness for the ecu.
i'll need some more info on what and how you're planning to do this swap for more info.
Old Nov 12, 2008 | 09:53 AM
Default Re: DA swap help? (super jdm yo)
thanks man, you are talking about the teeth count on that main piece from the transmission going through the clutch/pressure plate/ and into the flywheel bearing correct? and wondering would i need to use the flywheel for a 90-91
i have a 90 gs, with the stock transmission
with what you said with the intake, the problem is a p72 won't work with my chassis harness, so i need to used the chipped p28, in which case i hear you will have problems with the infamous butterflies of the stock gsr intake used without a p72 ecu, so i was going to use a skunk 2 intake/throttlebody to eliminate that
the main concern is the distrubutor, i am wondering if an obd0-obd1 conversion harness from rywire, will plug directly into the gsr distrubtor?
if not i was wondering, should i cut the extra leg on my obd0 distrubutor and use it, or swap dizzy internals from my obd0 to the obd1 gsr distrubutor
Old Nov 12, 2008 | 09:54 AM
Default Re: (LetsGetSerious)
not much pics of your da? mods?
Old Nov 12, 2008 | 10:37 AM
Default Re: (90tegblueonblack)
are you talking about my da?
but yeah the flywheel, it doesn't matter all flywheels are the same. i heard that type r ones are 12 pounds compared to the 18 pounds. umm i really don't know about the rywire conversion harness, you should call them they'll be more help since they made it.
hAtChBaCkFoReVeR
Mar 31, 2010 01:59 PM
90tegblueonblack
Nov 11, 2008 06:08 AM
mrbsponge
12
Jan 25, 2004 08:08 AM
hybridracer23
Jun 23, 2002 02:38 AM
importstart
Feb 28, 2002 06:01 PM
