iddle question
Old Oct 10, 2008 | 02:16 AM
jhojhet's Avatar
Default iddle question
It recently started that my RPM goes up and down between 1500 to 2000 at all times until the temp goes normal. Does anyone experience this and can help me out probably fins out what causing this problem? I know something is wrong since this was not happening before.
Old Oct 10, 2008 | 02:24 AM
DaveF's Avatar
Default Re: iddle question (jhojhet)
check for vacum leaks @ the throttle body ( make sure you are using the proper thottlebody gasket)
if you are using some junk blow off valve, (ebay) it might be leaking from the outlet, past the cylinder, and into the vacum hose.
if you have a fast idle thermo valve, it may have come loose. you will need to take off the 2 bolts and metal plate from the backside, and tighten the white screw piece. (you might want to remove it all the way, and put some loc-tite on the threads, then put it back in and tighten it all the way, so it doesnt come loose again. )
MrExclusive
Feb 17, 2010 08:41 AM
96b16sprayin
Mar 16, 2009 12:45 PM
TylerC161
Jan 24, 2008 03:10 PM
T3T495GSR
Jan 3, 2006 08:57 PM
topher
Mar 22, 2002 12:56 PM
