brake boost
Old Oct 4, 2008 | 11:22 AM
avotegra's Avatar
Default brake boost
have anyone try doing a brake boost roll race...............how do you do it.....just wanna know.....................
Old Oct 4, 2008 | 12:06 PM
stiffdogg06's Avatar
Default Re: brake boost (avotegra)
Example:
Cruising at 60mph, down shift to 3rd gear, slightly push the brake down WHILE at the same time pushing the gas at the same time pretty hard and you will build boost and then let go of the brake and your off...
thats a quick break down. I am sure someone will get more technical.
Old Oct 4, 2008 | 12:59 PM
LastGenEK's Avatar
Default Re: brake boost (stiffdogg06)
^ Thats it!
Iv tried but never hold it long enough!
Old Oct 4, 2008 | 03:04 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stiffdogg06 &raquo;</TD></TR><TR><TD CLASS="quote">Example:
thats a quick break down. I am sure someone will get more technical.</TD></TR></TABLE>
pretty good explanation right there, pretty common with the supra guys... your basically just creating more load so the turbo spools up sooner.
Old Oct 4, 2008 | 09:52 PM
avotegra's Avatar
Default Re: brake boost (blinx9900)
does it work on our cars.....
Old Oct 4, 2008 | 10:01 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avotegra &raquo;</TD></TR><TR><TD CLASS="quote">does it work on our cars.....</TD></TR></TABLE>
if your front tires are stick enough.
Old Oct 5, 2008 | 09:10 AM
96 GSR-T's Avatar
It works wonderful on my car, I could brake boost 20psi in 4th gear on the interstate very easily, which would only lead to destroying the tires instantly, you dont need much just get the turbo into some boost and punch it, I will never let a V8 get the jump on me in a roll race. Be aware that you will only be able to build as much boost as your WG spring is rated to obviously and it isnt exactly my idea of being friendly to driveline parts, but much better than just shocking them IMO.
lovin'my type-s
17
Apr 17, 2007 07:11 AM
killablaze
Feb 4, 2006 03:16 AM
LostSolVTEC
Aug 15, 2005 07:23 PM
budget
Mar 28, 2005 11:45 AM
Hyaboosta
Mar 3, 2005 08:20 AM
