RC injector installation help.
Old Oct 10, 2008 | 01:15 PM
Whatever's Avatar
Default RC injector installation help.
I bought a used set of RC 550cc injectors from a guy on hear about a month ago and when I went to install them today I realized they don't fit very snugly in the intake manifold. The top where it goes into the fuel rail is fine but it's not a nice tight fit in the intake manifold like the stock ones are. The part number is PL9-550 and a google search says they fit:
92-95 Honda Prelude OBD1 (H22a, H23)
90-95 Honda Accord OBD1 (F22a, F22b)
Am I screwed or can I make these work somehow?
Modified by Whatever at 5:34 PM 10/10/2008
Old Oct 10, 2008 | 01:19 PM
champLSinteg's Avatar
Default Re: RC injector installation help. (Whatever)
Did you tighten down the fuel rail? They should be snug against the rubber o-ring in the manifold once you tighten the rail.
Old Oct 10, 2008 | 01:26 PM
Whatever's Avatar
I was just messing with it a bit more and it doesn't fit down far enough into the manifold for the fuel rail to be tightened down all the way. I don't want to force it down and screw things up more either.
Old Oct 10, 2008 | 01:35 PM
Whatever's Avatar
I just found this:
apparently they are supposed to come with new rubber piece for where they sit in the intake manifold. I have no idea where to get just those pieces.
Old Oct 10, 2008 | 04:38 PM
B18EG6's Avatar
here is a thread I made a while ago that might help you out
https://honda-tech.com/zerothread?id=1923862
Old Oct 10, 2008 | 05:14 PM
Whatever's Avatar
I'll check it out now but I think I figured it out. I emailed RC and they sell the "cushion" for $2.50 a piece.
Old Oct 13, 2008 | 08:21 AM
Whatever's Avatar
So I called today to order the lower manifold seals and the guy told me they are the same as the stock ones but there is supposed to be a plastic piece under the seal that remove and then you reinstall them. Well I have no such plastic piece and when I tried to tighten the rail down on the stock lower seals is started to compress the crap out of the rubber piece that sits on top of the injector. I've seem some guys run a spacer on the studs where the rail bolts up to the manifold and some guys talk about dremeling out the stock seals. Does it matter which way you do it?
Old Oct 13, 2008 | 08:55 AM
B18EG6's Avatar
Default Re: (Whatever)
if it helps, I ran spacers on the connection between the rail and the manifold I have pics if it will help
Old Oct 13, 2008 | 08:58 AM
Whatever's Avatar
I've heard of people doing that. I just figure there is a certain gap that needs to be maintained in order for the fuel to atomize correctly. It seems that putting spacers on the studs is the way most people do it...
Old Oct 13, 2008 | 09:01 AM
dpetro1's Avatar
everything sounds fine to me. you have the instructions from RC so i would follow them. if you are worried about the upper cusions getting smashed then get a spacer but i think you should just torque everything to spec and call it a day
Old Oct 13, 2008 | 09:05 AM
Whatever's Avatar
I'll figure something out...
ieatrice
14
Jun 7, 2007 02:26 PM
Roid
Oct 26, 2006 06:17 PM
SkoundrelUSA
Sep 2, 2006 07:32 PM
Steak84SS
Mar 20, 2005 08:44 AM
aemciv
Mar 24, 2003 11:34 PM
