Injector Pulse Noise
Old Oct 5, 2008 | 06:13 PM
kte324's Avatar
Default Injector Pulse Noise
I have a turbo ls/vtec that has 1000cc rc injectors. The car puts about 505whp to give you an idea. When the car was built I had thought I was injector noise but then some people are telling me that it might be my head. Or maybe needing a valve adjustment. The noise is not crazy loud like something is broken but you can still hear it. Do yall have injector pulse noise?
Old Oct 5, 2008 | 06:29 PM
non-VTEC's Avatar
Default Re: Injector Pulse Noise (kte324)
1000cc injectors at idle are opening/closing very slowly. i doubt you are hearing that over the valve train noise.
even if its not at idle the ammount of engine/valve train noise on a b-series cylinder engine is alot. what you may be hearing is just the valve train working away.
do a valve adjustment and see if what you are hearing goes away.
Old Oct 5, 2008 | 06:30 PM
stiffdogg06's Avatar
i know my DSM's are loud.
But yeah try a valve adjustment and see if it helps. I mean it couldn't hurt.
Old Oct 6, 2008 | 03:14 AM
DaveF's Avatar
Default Re: Injector Pulse Noise (stiffdogg06)
ive never heard a set of injectors as loud as 160lb injectors.
perhaps you need some new LMA's
Old Oct 6, 2008 | 06:20 PM
kte324's Avatar
well I was thinking either lma's, injectors, or maybe just needing a valve adjustment. How could I check if it is the lma's or injectors??
Old Oct 6, 2008 | 08:17 PM
quicksilver1689's Avatar
i ♥ snails
Default Re: Injector Pulse Noise (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">1000cc injectors at idle are opening/closing very slowly. i doubt you are hearing that over the valve train noise.
do a valve adjustment and see if what you are hearing goes away.</TD></TR></TABLE>
wouldnt they be opening and closing as fast as possible for a very low pulse width because at idle fuel requirements are very minimum on those sized injectors.
whiteboy-dc4
Feb 13, 2009 01:31 PM
Tegraracer90
Jul 23, 2008 05:48 AM
boomersz
23
Apr 28, 2007 10:43 AM
SleepnCiViC
Feb 14, 2004 01:49 AM
Luke
Feb 17, 2002 09:26 AM
