How long before i throw a code
Old Oct 7, 2008 | 11:11 AM
Speed94's Avatar
Default How long before i throw a code
if I swap out to factory ECU and injectors?
Old Oct 7, 2008 | 11:33 AM
tony413's Avatar
Default Re: How long before i throw a code (Speed94)
if the ECU tells you what codes you throw
and you plan on swapping that out
how will you know if you throw a code
Old Oct 7, 2008 | 11:44 AM
Schister66's Avatar
Man U FTW
so...factory ECU and injectors + boost??
I think i may be missing something, but if that's correct, that's a REALLY bad idea unless you're totally babying it
Old Oct 7, 2008 | 02:40 PM
Speed94's Avatar
dont want to, but might have to for inspection. Ill probably swap out for factory injectors too. Its a boosted integra
Old Oct 7, 2008 | 03:11 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Speed94)
stock injectors and stock ecu, if you have a different map sensor you need to plug that in as well.
just make it back to stck and dont boost. acutally jut change it outside before you go inside to get the inspection.
Old Oct 8, 2008 | 06:57 AM
Speed94's Avatar
Default Re: (HybridcivicLS-T)
i have a GM 3 bar in it right now...so all I have to do is pout back stock injectors, ECU, and get rid of the Mapsensor and I shouldnt throw codes? I think Im going to disonnect one of the cold side pipes to make sure it doesnt get any boost.
Old Oct 8, 2008 | 08:06 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
that should fix you.
stoneys88hatch
Engine Management and Tuning
Oct 22, 2010 06:22 PM
SCerbanger
Jun 17, 2010 07:40 AM
lazyvietboi
Dec 4, 2009 03:34 PM
crxforum
Jun 12, 2004 06:07 PM
