puff of white smoke when trying to start?
Old Oct 3, 2008 | 08:44 AM
turbo-crx's Avatar
Default puff of white smoke when trying to start?
i just assembled my motor again. when i went to start it the first time a huge cloud of white smoke came out of the intake i believe and out of the breather on the vc and the catch can line from the back of the block(i didnt have it connected to the catch can yet)it ran for a few seconds and when i tried to give it gas it shut off
i have fuel, timing, and compression. the wires, plugs and dizzy are all new. i notice when i try to crank the car it turns over slowly, so i put it on a charge over night and it still cranks slowly. m not throwing a cel either. iv never had a problem like this before putting a car back together.
ls/vtec
81mm wiseco
eagle
1000cc
t4/60-1
stock ignition
3 bar
i pulled the plugs and they have fuel just dripping off of them, so im def not getting spark.
Old Oct 3, 2008 | 09:22 AM
totsie7944's Avatar
Default Re: puff of white smoke when trying to start? (turbo-crx)
Sounds like you forgot to put a headgasket on lol...
Seriously I'd see if you have coolant blowing into your cylinders....white smoke is a sign of coolant. That definatley would keep you from running rihgt and if theres enough in there it will be hard turning over...I know this because its whats wrong with my car right now..the Cometic headgasket I have sucks, never will I buy from them again.
Old Oct 3, 2008 | 10:33 AM
turbo-crx's Avatar
Default Re: puff of white smoke when trying to start? (totsie7944)
lol. i have a hg on. i did a comp test and comp is perfect. i dont see how coolant would get into the cylinders though. i looked down into the cylinders and didnt see any coolant in there.
Old Oct 3, 2008 | 10:53 AM
totsie7944's Avatar
Hmm well pull the plugs and let the fuel evaporate.
I'd consider changing the plugs. However you can you anything metal to see if your getting spark by pulling the plugs, keeping them connect to the wire (just don't get shocked), turning over the motor. Read up on checking spark...That would be my first guess.
Might be stupid...do you have the dizzy wire harness connected to the dizzy? lol...make sure its tight...make sure you have the right dizzy...
Old Oct 3, 2008 | 11:23 AM
turbo-crx's Avatar
yea im gona check for spark when i get home.
all the connection are hooked up and correctly. hopefully the dizzy didnt fail after only two weeks
Old Oct 3, 2008 | 08:22 PM
platinum00's Avatar
Is the motor broke in? If your compression and leakdown are coming back clean put some miles on it and see what happens.
aaronISthrowed
14
Oct 19, 2011 09:52 PM
spoolinvtec54
Mar 15, 2011 12:21 PM
Inf^Shini
Oct 30, 2007 09:27 PM
Cyber ITR
Feb 1, 2007 12:36 AM
LsVtakYO
Jan 24, 2006 11:13 AM
