b16a turbo tell me what you think?
b16a ctr tranny with 6 puck act
525 injectors pt with skunk 2 intake mani
walbro 255
drag manifold
SC44 60/63ar
tail wastegate 11.7 spring
shootin for 300 whp
walbro 255
drag manifold
SC44 60/63ar
shootin for 300 whp
Re: b16a turbo tell me what you think? (418whpturboD)
300hp on just the spring is gonna be hard with a B16. but it looks like your on the right track. Just save up some money and get a healthy 1.8 bottom end under that vtec head. And get rid of the log manifold. its gonna hurt ya for power
FWIW, i made 357whp on 12psi with a misfireing MSD wire. On my ls/vtec. it just takes more boost with the small block. Good luck man
Re: b16a turbo tell me what you think? (stockb18c)
You should get close to 300whp on that set-up. The log manifold will hurt you a tad on the b16a but here is a dyno chart from a similar set-up that I tuned a few months back. The turbo was a little smaller but it took 13psi to hit 309whp.
looks almost identical to my first setup i loved the b16 on the street got good traction one of my favorite motors back when my car was still a daily! nice choice in parts .. A nice ram horn will help you reach your power goal at that boost level.
Re: (stockb18c)
manifold is a major restriction and possible cause for potential boost creep problems, i good luck, im guessing you will probably see closer to 15psi with that spring and manifold... very nice intercooler by the way...
looks almost identical to my first setup i loved the b16 on the street got good traction one of my favorite motors back when my car was still a daily! nice choice in parts .. A nice ram horn will help you reach your power goal at that boost level. the ctr trans will be fun can u say rev limiter
Re: b16a turbo tell me what you think? (23hatchturbo)
given its a log mani but just a little nicer. my setup 280hp at 9 lbs. i think if you run that sping you should be almost spot on 300 with a nice tune.
peter-ek4
04-11-2008 05:05 AM
