car died
Alright well i've got a integra ls turbo and my car recently just died on me. It was running on basemap and it only had a 3lb spring. I've checked for spark and i've got good compression, but i'm not getting fuel. The injector clips are getting power but the injectors aren't spraying and i have no clue what's wrong, so i need opinions.
Well, judging by EXACTLY whats in your post, it looks like you forgot to check fuel pressure at the rail. Check the fuel pump. First just sit in the car and make sure it's super quiet, turn the key one click and see if you can hear the pump priming. If there isn't pressure to the rail. Problem = Fuel pump. Good luck
you're pump is priming, you're getting the right fuel pressure, injectors are getting power...If you're getting the right pressure, then i would say the problem is somewhere after that. It would be weird to see all 4 injectors shitting out at once, unless it was electrical related. How did you check to see that the injectors weren't spraying? Maybe they should be sent out to be tested.
i have precision 440cc saturated injectors <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_raffi »</TD></TR><TR><TD CLASS="quote">you're pump is priming, you're getting the right fuel pressure, injectors are getting power...If you're getting the right pressure, then i would say the problem is somewhere after that. It would be weird to see all 4 injectors shitting out at once, unless it was electrical related. How did you check to see that the injectors weren't spraying? Maybe they should be sent out to be tested. </TD></TR></TABLE>i took it out of the manifold and check to see if any fuel was coming out and i took my sparkplugs out and put a papertowel over the cylinders then cranked the car to see if there was any fuel coming out.
how did you check for power at the injector clips? did you use a noid light or did you check it with a multimeter because the multimeter method is useless because the injectors open on ground signal not power.
oneslowcivic
Sep 19, 2003 08:02 PM
