Boost Situation?
Old Oct 3, 2008 | 09:06 AM
whitehatchguy's Avatar
Default Boost Situation?
Here is what i have. The car is a 98 integra and the engine is a b20 sleeved by Blueprint Racing with a diamond bore\hone wiseco 9:1 turbo pistons (stock bore) eagle h beams stock crank, b16 head skunk2 valves spring and retainers (undecided on wich cams to run) built by alamo autosports and my fuel management is a s300. My goal is to get in the 500-550 hp range and retain my ps and ac. Will this be possible with a t3-t4 and how do i determine what sensors and injectors will be needed? I am not new to honda's but i am new to turbo so any links to threads on turbo theory would also be appreciated.
Old Oct 3, 2008 | 09:18 AM
totsie7944's Avatar
Default Re: Boost Situation? (whitehatchguy)
Well are you thinking pump gas or race gas?
I just made 540 whp while keeping AC, PS, and ABS...but I had to drop a ton of money into my car for the right motor build, manifold etc. You can hit your power goals with a GT35r, however, not many tuners are comfortable going above 500 whp on pump gas...I just have one of the best tuners out there.
I can help guide you, however I am thinking you are going to need a bigger bore and stroke to get near the power you want on pump gas...race gas you will be fine.
thatblkguy's Avatar
u need to look for a manifold that is ps and ac ready
Old Oct 3, 2008 | 09:28 AM
totsie7944's Avatar
Default Re: (thatblkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy &raquo;</TD></TR><TR><TD CLASS="quote">u need to look for a manifold that is ps and ac ready</TD></TR></TABLE>
To the OP I didn't see you have a B20 block....what stroke is that crank?
Old Oct 3, 2008 | 09:31 AM
Default Re:
I would like to run pump gas because i live in the middle of nowhere texas the best i can come across is 91 but seeing how it would be a weekend car to drive to dallas occasionaly i would be able to consider it.
Old Oct 3, 2008 | 09:36 AM
Default Re: Re:
i think the stock stroke is 89mm
Old Oct 3, 2008 | 10:15 AM
totsie7944's Avatar
Default Re: Re: (whitehatchguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitehatchguy &raquo;</TD></TR><TR><TD CLASS="quote">I would like to run pump gas because i live in the middle of nowhere texas the best i can come across is 91 but seeing how it would be a weekend car to drive to dallas occasionaly i would be able to consider it. </TD></TR></TABLE>
Well with 91 octane I'd personally advise you only shoot for like 450 whp....Call me conservative, but a 450 whp motor with AC is more fun than a paper weight...lol.
Let me know if you are really serious and I will help guide you with parts, tuning, etc. I kept of entire list of my build...I'm getting ready to make a thread in a little while later today..so you can refer to that for starters..give me like 30-60 mins
Old Oct 3, 2008 | 11:17 AM
Default Re: Re:
safely would be the the way to go because im gonna have a good amount invested and i dont want have to invest it again just because i made shortcuts now
Old Oct 3, 2008 | 11:22 AM
totsie7944's Avatar
Yea check out the thread I just made in forced induction....its my parts list. Its the best parts out there.
Old Oct 3, 2008 | 11:26 AM
Default Re: Re: (totsie7944)
how many lbs are you pushing?
Old Oct 3, 2008 | 12:29 PM
totsie7944's Avatar
21 lbs made 540...19 made 507. Keep in mind boost doesn't matter....what I run is irrelevant. Turbo size, motor, etc, everything effect how much power 1 lbs of boost really makes.
Old Oct 3, 2008 | 12:35 PM
Thats what im trying to understand. You would think 21lbs is 21lbs just how fast it gets to 21lbs would be the difference.
Old Oct 3, 2008 | 12:56 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitehatchguy &raquo;</TD></TR><TR><TD CLASS="quote">Thats what im trying to understand. You would think 21lbs is 21lbs just how fast it gets to 21lbs would be the difference. </TD></TR></TABLE>
Everything is a variable...21 lbs on a D-series won't make the same power as 21 lbs on a B series. Displacement, turbo size, compressor housings, exhaust housing, all come into play. Just use the search function...there are 100's of threads on this type of stuff.
Old Oct 3, 2008 | 02:52 PM
I have been reading up all day and i am starting to get this to make sense to me.My question now is how to i calculate wich trim and ar is right for my power and usage goals.
Old Oct 3, 2008 | 06:36 PM
totsie7944's Avatar
Well it depends if you want faster spool or more highend power....Just research some more on it.. But for instance a .62 CR housing on a GT35r will spool faster with less high end power than a .82
datsun71
Aug 1, 2012 08:13 AM
eljah0426
Dec 27, 2010 04:24 PM
99blusi
Nov 25, 2005 04:39 PM
non-VTEC
Oct 9, 2004 11:58 AM
