coolant loss
Old Oct 11, 2008 | 11:21 PM
4dek's Avatar
Default coolant loss
its a boosted d16 and its losing coolant but i dont see any leaks???someone help me pls....
Old Oct 11, 2008 | 11:44 PM
H22Luda720's Avatar
Default Re: coolant loss (4dek)
Is the turbo water cooled?
Do you see white smoke coming out of the exaust?
Did you read the plugs?
Old Oct 12, 2008 | 12:02 AM
4dek's Avatar
Default Re: coolant loss (H22Luda720)
nope turbo isnt watercooled. will check the plugs tomorrow but what should i look for?
Old Oct 12, 2008 | 12:15 AM
H22Luda720's Avatar
Start with pulling them out and see if one is different than the rest.
Old Oct 12, 2008 | 12:27 AM
FERIO916's Avatar
i have that same problem im running a greddy turbo on my d16y8 and have a coolant leak but dont know where its coming from and mine blows smoke out of the exhaust by checking the plugs and finding one that is different what does this mean ? i know i am running NGK civic HX plugs cause its a colder plug ????????????
Old Oct 12, 2008 | 12:36 AM
H22Luda720's Avatar
Default Re: coolant loss (FERIO916)
Normally your plugs will have some carbon build-up on them, if one cylinder is burning coolant it will have a "steam cleaning" effect on that plug. So just make sure they look the same across the board.
Old Oct 12, 2008 | 12:46 AM
4dek's Avatar
so how will a plug look like if coolant is leaking internally?
Old Oct 12, 2008 | 04:13 AM
yakuza's Avatar
If the plug is being exposed to coolant it will either have no or minimal carbon residue on it or would have kind of white colourish.
Old Oct 12, 2008 | 03:05 PM
H22Luda720's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">so how will a plug look like if coolant is leaking internally?</TD></TR></TABLE>
Also check you oil level, make sure its not overfull, could be mixing
Old Oct 12, 2008 | 06:06 PM
jspeedy's Avatar
I had the same prob for a year. My oil looked more and more strange as time went on. I did not notice any smoke but the end result was I had coolant mixingw/oil due to my block deck not being straight from a previous blown head gasket.
Old Oct 13, 2008 | 11:02 AM
neoc03's Avatar
Hoping it's not, but it sound very likely to be a headgasket. They are pretty easy to do on Hondas. Especially the SOHC motors.
Old Oct 13, 2008 | 12:01 PM
muasboi's Avatar
i'm also running the G-ready kit
for the longest time i was losing coolant too. just little by little though, nothing majorly drastic. i looked over my coolant lines, and found the one by the intake mani leaking (prob only under boost). anyways it just needs a new clamp.
but maybe check your lines too, maybe you have a similiar issue.
Old Oct 13, 2008 | 02:47 PM
4dek's Avatar
Default Re: (muasboi)
ok i think its my head gasket cause i checked the plugs before and i noticed that cyl 1 plug looked like spankin brand new and the rest have a slight brown tint on it so i think thats what it is. maybe arp head studs would solve my problem. will it be ok to run my car for about 5 months without fixing this? the leak isnt really that bad, i only add coolant every week about 1 cup
Old Oct 14, 2008 | 02:38 PM
muasboi's Avatar
yes, just don't boost. you should be fine.
Tenji
Jun 25, 2015 07:57 AM
lfdelar2
Aug 22, 2013 06:12 PM
EGwhat!!!
19
Mar 12, 2008 01:23 PM
Tenji
Apr 30, 2007 02:15 AM
hondura
Dec 15, 2002 01:28 PM
