headgasket for 84.5mm turbo GSR
Which head-gasket would be the best for my GE sleeved 84.5mm GSR block?
I will be running a GT30R on my street driven set-up. I'd like to get a OEM Honda head-gasket. But do they make a 84.5mm bore?? What are you guys running in your turbo GSR setups?? Are there any head-gaskets out there that get close to OEM Honda quality??
Any help or tips on head-gasket sealing is greatly appreciated.
Re: headgasket for 84.5mm turbo GSR (cartel420)
Get the one under the one I have highlighted, I run the highlighted one on my GE sleeved 84MM B16 block fully built, it made 260@9PSI on 93 octane conservative tune... it is a stock headgasket bored to the right size and my engine sealed up perfect with it. Cheaper than OEM HG too!
Hey, thanks man. How long has your motor been turbocharged and running with the highlighted headgasket? Come on guys, there has to be more than one person running a big bore turbocharged sleeved b-series.
im running a GE 84mm headgasket too. you wont have any issues with those gaskets. they use OEM honda gaskets and CNC out the bore to whatever size you want.
Re: headgasket for 84.5mm turbo GSR (non-VTEC)
i have a cometic 84mm head gasket for a a GSR motor, lemme know if u want buy it. I needed one for a LS, but ordered this on accident.
.040 MLS Headgasket.
Re: headgasket for 84.5mm turbo GSR (CerealKiller)
my setup isn't bored at 84mm, nor is it sleeved. However, I'm using a Cometic .051" MLS for my 81.5mm setup. Everyone will say something different though.
we also use Cometic on the Supra 7MGT we're working on.
Re: headgasket for 84.5mm turbo GSR (redlinetuning)
I think the answer is simple. You want an oem head gasket that'll fit your 84.5mm bore motor.
Golden Eagle 84.5mm bored oem honda headgasket.
I've ran one in my 84mm, 84.5mm and 85mm boosted setups at over 30psi with no issues, never blown a headgasket.
SPOON_BeIgHtEeNsEe
03-11-2004 08:09 PM
