Victor X manifold and 76mm throttle body?
Can a Victor X manifold be port matched to a Blox 76mm throttle body w/o interfering with the Idle Air Control Valve? If yes, will it run correctly?
Re: Victor X manifold and 76mm throttle body? (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 »</TD></TR><TR><TD CLASS="quote">yes. I have that setup but using the RPM throttle body.</TD></TR></TABLE>
Did you modify your IAC?
Re: Victor X manifold and 76mm throttle body? (HotboxedTypeR)
i ported mine out to 75mm and there was some room left for the iac to work properly, not a lot but enough for that. I still disconnected my iac and like it much better without it on there at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotboxedTypeR »</TD></TR><TR><TD CLASS="quote">
Did you modify your IAC?</TD></TR></TABLE>not at all. Idle is like stock
Re: Victor X manifold and 76mm throttle body? (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">for what its worth, you really dont need an iac at all, the idle can be adjusted with the tune</TD></TR></TABLE>
can the s300 b tuned without and iac?
Re: Victor X manifold and 76mm throttle body? (jdm inc)
i ported mine to 77mm for a 1mm step and im running the blox 76mm throttle body victor x with iac no problems proubly over kill though. thats what my tuner said, what do you guys think. But ya can be done with no problems
im running the victor x and 76mm throttle body but havnt ported the intake yet it needs it but i just threw it on there. i think its overkill for the setup i have. i had a 65mm elderbrock tb on there before. but now im having problems with the throttle cable being to tight or not opening all the way.
Civic_95_Si
08-08-2003 10:11 PM
