turbo price
Old Oct 10, 2008 | 09:42 AM
Theredline's Avatar
Default turbo price
Have a garrett m24 .60 turbo. Wondering what the model number is and what it could sell for! All i know that it is for a b16 motor, honda civc/integra.
Thanks
Old Oct 10, 2008 | 09:58 AM
Schister66's Avatar
Man U FTW
That tells us nothing. The .60 is the ratio on the compressor housing and the M24 i believe is the casting or the material for the casting. Basically you said you have a turbo and nothing more. Get pics at least!
Old Oct 10, 2008 | 11:15 AM
Theredline's Avatar
Default Re: turbo price (Theredline)
those are the pictures i could take atm
Old Oct 10, 2008 | 03:49 PM
Schister66's Avatar
Man U FTW
I can tell you its a straight T3. It looks like it should have an internal wastegate judging by the 5 bolt to 3 bolt turbine housing, but theres no actuator for it. You'll have to measure the wheels in order for us to give you an exact model and size...
Old Oct 10, 2008 | 04:11 PM
HiProfile's Avatar
Default Re: (Schister66)
Well you're right it looks like the flapper has been removed, but I doubt its a straight-T3. That looks most like a t04b cover and v-trim t04b wheel to narrow it down. I have an s-trim t3/t04b with that same 3" in/2" out cover; it also has the same 16-blade wheel which is common to certain t04b's.
As far as the turbine, I really hope the flapper hasn't been welded inside of the wg housing, thats just a waste of space, among other things. It looks like its a stage-1 garret T3 turbine, as the fins are really folded over, and I've really got the mental picture of that wg housing/wheel size combo stuck in my head.
If that's the case, it would be worth $500 new, but $275-375 used. I picked mine up for $200. its good for people who want good power, but excellent spool. The extra compressor blades and smaller turbine will spool it a few hundred rpm faster, at the cost of not getting a flat torque line.
Cliffs: <U>t3/t04b</U>, v-trim compressor (IIRC 42lb/min - ~390whp), stage-1 turbine (some people say 250whp is too much for it). You'd really want to take the 2 covers off, measure both wheel's small and large diameters, then you (we) will know exactly what you have.
Old Oct 10, 2008 | 05:49 PM
Theredline's Avatar
Default Re: (HiProfile)
That helps out alot thank you! I really dont know the full specs of everything but that helped out alot since im trying to sell this.
Just needed a basic price range for it, and now just need to calculate it with these items.
# XS Power Waste Gate
# XS Power Downpipe
# XS Power Exhaust Manifold (Headers)
# Greddy Type-RS Blow off Valve w/ Vaccuum Line
Dont know if anything was ever used. Work at a ebay drop off store and found this in the back room, was sittin there all packaged up for about over a year.
9TechNine9
Aug 2, 2016 11:33 AM
954bballer091
Sep 7, 2008 05:16 PM
boostedsi1
Mar 17, 2004 06:47 AM
trbcivic
Sep 22, 2003 11:58 PM
