built GSR bottom end ?
Old Oct 7, 2008 | 07:07 AM
delusionracer's Avatar
Default built GSR bottom end ?
i have a built obd2 gsr bottom end. i was going to put it in a obd2 gsr but plans have changed. i want to use built gsr into a 95 gsr. will the crank sensor be a problem since the crank sensor in the distributor on the obd1?
Old Oct 7, 2008 | 07:12 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: built GSR bottom end ? (delusionracer)
move the crank sensor from the obd2 to the obd1 bottom end and your good
Old Oct 7, 2008 | 09:35 AM
Schister66's Avatar
Man U FTW
Default Re: built GSR bottom end ? (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">move the crank sensor from the obd2 to the obd1 bottom end and your good</TD></TR></TABLE>
Is that necessary?? I didnt swap over my crank sensor to my OBD1 LS block on my LS/VTEC...maybe that's what's causing my starting issues.
BTW: OBD1 LS block and OBD2 GSR head
Old Oct 7, 2008 | 02:40 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: built GSR bottom end ? (Schister66)
your on an obd1 ecu......it doesn't hurt to hook it up. I know the car runs like crap if it's not hooked up on an obd2 motor and an obd2 ecu. I dont think thats your problem.
honda2ksi
Jun 24, 2010 01:45 PM
killerpenguin21
May 23, 2007 04:06 PM
b20_ed
Nov 10, 2005 12:25 PM
BlkSIvic
Sep 1, 2004 10:12 AM
Civic
Dec 14, 2003 11:51 AM
