TiAL Q BOV Help.
Old Oct 1, 2008 | 08:02 AM
Manny1987's Avatar
Default TiAL Q BOV Help.
I'm getting all my parts together for my LS EK and I dont know what spring to get for my BOV. Does anyone know what spring I need. Im looking at it on No Limit Motorsports.com and they have 7,9,11psi springs available does anyone know which one I need. Also has anyone ordered from them or JDM Ultimate?
Old Oct 1, 2008 | 08:20 AM
TiAL's Avatar
Default Re: TiAL Q BOV Help. (Manny1987)
what do you pull for vacuum at idle when the car is at opp temp
Old Oct 1, 2008 | 08:42 AM
Manny1987's Avatar
Default Re: TiAL Q BOV Help. (TiAL)
My friend said I pull 10 to 15.
Old Oct 1, 2008 | 09:09 AM
TiAL's Avatar
that's like saying i drive between 30 and 70mph
it needs to be exact
Old Oct 1, 2008 | 09:12 AM
KillAHonDa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">that's like saying i drive between 30 and 70mph
it needs to be exact</TD></TR></TABLE> LMAO!
Old Oct 1, 2008 | 09:33 AM
TheShodan's Avatar
Moderator
Default Re: TiAL Q BOV Help. (KillAHonDa)
If its a B-series honda still using base timing, more than likely it will be an 11 to 12 pound spring. This will change if you have a lot of T's off of the brake booster, or another main vaccum source.
Old Oct 1, 2008 | 09:46 AM
Manny1987's Avatar
Im going over to his shop here in a bit to check. Ill keep you guys posted on what it is exactly.
Old Oct 1, 2008 | 09:47 AM
AWD Terror's Avatar
Agreed
Old Oct 1, 2008 | 02:54 PM
19slocivic97's Avatar
no limit
had great cust service and shipped fast
Old Oct 1, 2008 | 09:40 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: TiAL Q BOV Help. (19slocivic97)
http://www.tialmedia.com/docum...p.pdf
Old Oct 2, 2008 | 09:08 AM
ironcheftony's Avatar
well i have a tial q with a 10/11 psi spring the one for a honda, and it eventually blew out my turbo, because it wouldnt blow off all the time during low boost and it would compressor surge
i highly doubt it was my vacum source or my setup, the turbo was fine untill after i put the tial q on there
i would look into a lower psi spring around 7psi or so, if your setup is for low boost, it will help blow off at lower boost
just from my expreience
Old Oct 2, 2008 | 09:34 AM
twkdCD595's Avatar
Default Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">well i have a tial q with a 10/11 psi spring the one for a honda, and it eventually blew out my turbo, because it wouldnt blow off all the time during low boost and it would compressor surge
just from my expreience</TD></TR></TABLE>
WHAT? blew out your turbo because of tial. honda one. spring selection by boost pressure.
oh my, where to start.
you select a spring by the tialsport chart of how much vac you pull at idle fully warmed up, there is no "honda" one. you seem to think the spring pressure rating in psi is directly related to the boost pressure your pushing for selecting a spring, WRONG!
blew out your turbo cause of the tial Q? I would love to see some factual information to back that up. you do realize there are quite a few application that dont use a BOV AT ALL without a problem. including race cars and whatnot.
What I highly doubt, is that you would have any idea if it was your vac source or setup after reading your post since your totally misinformed.
Old Oct 2, 2008 | 09:35 AM
TiAL's Avatar
post up pics of your thrust bearing
Old Oct 2, 2008 | 12:01 PM
Manny1987's Avatar
Just check out my vac. its at 10 with the car at normal operating temp. Im trying to pull up the TiAL web link above to get the facts but im at work and these stupid PC's wont let me open the page. (Government Crap) ?
Old Oct 2, 2008 | 12:02 PM
Manny1987's Avatar
Which Spring do I need for the TiAL Q BOV with my car pulling 10?
Old Oct 2, 2008 | 12:18 PM
Default Re: (Manny1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manny1987 &raquo;</TD></TR><TR><TD CLASS="quote">Which Spring do I need for the TiAL Q BOV with my car pulling 10?</TD></TR></TABLE>
well according to that link i posted earlier, you would run a black-marked spring which is for vacuum readings between -8 and -11 in/Hg, specifically a -6 Psi (-12 in/Hg) Spring.
Good luck
Old Oct 2, 2008 | 12:53 PM
Manny1987's Avatar
No Limit Motorsports has 7,9,11PSI springs which one would be best? 7 right?
Modified by Manny1987 at 2:33 PM 10/2/2008
Old Oct 2, 2008 | 03:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manny1987 &raquo;</TD></TR><TR><TD CLASS="quote">No Limit Motorsports has 7,9,11PSI springs which one would be best? 7 right?
Modified by Manny1987 at 2:33 PM 10/2/2008</TD></TR></TABLE>
-7, -9, -11, and -12 springs are the options for the Older Tial version BOV.
-6, -8, -10, -11, and -12 springs are the options for the Newer, redesigned Tial "Q" bov.
Since your vacuum in at -10, it would either be the -7 spring (black) for the older Tial version BOV or -6 spring available (also black) for the newer "Q" bov.
Old Oct 2, 2008 | 07:42 PM
Manny1987's Avatar
Thanks for all the info Guys im going to order my BOV in the morning, I just got off work here on the East Coast its almost midnight.
Old Oct 2, 2008 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manny1987 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the info Guys im going to order my BOV in the morning, I just got off work here on the East Coast its almost midnight.</TD></TR></TABLE>
so are you getting the older Tial version or the newer "Q" bov?
Old Oct 3, 2008 | 01:17 AM
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">
What I highly doubt, is that you would have any idea if it was your vac source or setup after reading your post since your totally misinformed. </TD></TR></TABLE>
actually no i did not relate it to boost pressure, all my hondas ive owned pull vacuum of 20inHg on a fully warmed engine, i dont know if yours is the same
i have tried different sources for vacuum and its the same, and my car is not a race car, i believe the spring was just a tad stiff for my setup
i can make the can "blow off "but i would need to seel full boost or close to it, i cant get mine to blow off at 7psi
im sorry that you think im dumb, but i do know a few things
what do my thrust washers have to do with it ?
i dont
Old Oct 3, 2008 | 09:58 AM
Manny1987's Avatar
Default Re: (JDM turbo DC)
Im getting the New one w/ the black spring.
Old Oct 3, 2008 | 10:03 AM
Manny1987's Avatar
Has anyone ever ordered from JDM Ultimate? Im about to order my Intercooler and I just want to make sure there a good site. I got them off of here, they had a link (banner) up top on one of the threads I was reading somewhere.
Old Oct 3, 2008 | 10:20 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manny1987 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone ever ordered from JDM Ultimate? Im about to order my Intercooler and I just want to make sure there a good site. I got them off of here, they had a link (banner) up top on one of the threads I was reading somewhere.</TD></TR></TABLE>
NOT an authorized distributor
Old Oct 3, 2008 | 05:57 PM
blinx9900's Avatar
i dont </TD></TR></TABLE>
unless you had a ball bearing turbo running 20+ psi i doubt surge killed your turbo.
vtechjunkie
Mar 30, 2010 01:25 PM
miguel329
Sep 29, 2008 08:38 PM
JLHDOHC
Aug 2, 2006 05:43 PM
Vtec92Civic
Dec 18, 2004 11:22 AM
gpomp
Feb 16, 2004 11:47 PM
