Clutch slipping? while freeway driving in high gear VIDEO
Not sure what it is but something tells me clutch. THe boost is steady and when I floor lets say 3rd it will normally get up to 5 grand then get stuck there for couple seconds then rise up again. Eveything else is good. Happend on two different trannys. Its and exedy stage on with pressure plate. thanks for replies
http://www.youtube.com/watch?v=Sgct6VhyYUw
Re: Clutch slipping? while freeway driving in high gear VIDEO (civicxxxb16a)
if the rpm gets "stuck" it has nothing to do with a slipping clutch. is your gas pedal to the floor in this video?
With a slipping clutch the motor will rev and the car will not accelerate.
Re: Clutch slipping? while freeway driving in high gear VIDEO (2point2)
I see makes sense. Yes im flooring it the whole time. From like 5 grand to 6 it will slowly accelerate and the car will slowly gain spead the from 6 to 7 grand it will clear up and accelerate normally. It just tweaks out normally around 5 to 6 grand and every gear.
Re: Clutch slipping? while freeway driving in high gear VIDEO (tony413)
Sounds like your tune around VTEC engagement to me. You don't happen to have a wideband in the car do you?
