TURBO B16
Old Oct 10, 2008 | 10:31 AM
dans00civicSI's Avatar
Default TURBO B16
I am wanting to turbo my 00 civic si. I am wanting to just sleeve the block and replace the pistons with JE. I will build the head. I am looking to run about 300 to 350hp. Will the crank and rods hold that much on an everyday driver and will i have to switch to obd1 to tune it or can i just get a stand alone and tune it that way. Please let me no im just looking for a 300+hp everyday driver and not blow it up.
Old Oct 10, 2008 | 10:52 AM
boosted_EM1's Avatar
Default Re: TURBO B16 (dans00civicSI)
for what your looking for i would just to pistons and rods and get a good tune
convert to obd1 with a jumper
Old Oct 10, 2008 | 10:54 AM
Default Re: TURBO B16 (boosted_EM1)
the problem is the the obd1 is emissions. i wont pass with obd1 cuz mines an obd2
Old Oct 10, 2008 | 11:00 AM
i know nothing about that because i dont have to worry about passing emissions..
Old Oct 10, 2008 | 11:12 AM
04silvep3's Avatar
well if your gunna boost your motor ur not gunna pass emissions with a good tune
Old Oct 10, 2008 | 02:43 PM
Snailor Built's Avatar
350 to the wheels and u dont need anything to reinforce the bottom, just a good turbo setup, good tunning maybe even throw in some ctr cams and IM
Old Oct 16, 2008 | 07:00 AM
flatblackhatch's Avatar
Default Re: (30lb_EM1)
if your going to do the pistons then while you have it apart just put the extra money into the rods the crank will be fine but just throw some rods in and be safe.
Old Oct 16, 2008 | 07:12 AM
Schister66's Avatar
Man U FTW
For the power you're hoping to make, building the bottom end is unnecessary. That's not to say you can't do it, but for your power goals, the stock bottom end will work just fine. For example, i made 315whp on my bone stock GSR for 2 years...and i daily drove it. If you have the money, building the bottom end isn't a bad idea...it gives you peace of mind
Old Oct 18, 2008 | 08:05 PM
EKB16MN's Avatar
Default Re: (Schister66)
How did you drive it for those two years? I would say you got lucky.
Old Oct 18, 2008 | 09:22 PM
drSquish's Avatar
why don't you get the greddy kit with two ecus. I believe the piggyback runs off your stock P2T ecu enabling you to pass emissions. Your second tune would be on Hondata or something of your choice with a custom map and extra boost.
Old Oct 19, 2008 | 11:20 AM
Schister66's Avatar
Man U FTW
Default Re: (EKB16MN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKB16MN &raquo;</TD></TR><TR><TD CLASS="quote">How did you drive it for those two years? I would say you got lucky. </TD></TR></TABLE>
To be 100% honest, i beat the living **** out of the car pretty much every time i drove it. I dont think luck has a lot to do with anything...i've seen several cars make more than that on the stock block and run hard for years. Actually, last summer Mike from SLS (local shop in Fargo and an HT sponsor) made 389whp on his stock B16 with E85 and a 57 trim. The car is still running around Fargo somewhere as far as i know...
With a good setup and a good tune, you can make 300-350whp without issue. Maintenance is key though
IHRTJDM
Apr 26, 2008 06:30 PM
turbogsr18
Feb 23, 2008 03:02 PM
urbansi
Oct 6, 2006 10:51 AM
ketchup!
Aug 5, 2006 04:29 PM
