how to check your head??
Old Sep 30, 2008 | 05:14 PM
laziebun's Avatar
Default how to check your head??
Well here my problem....Im F-ing scared that might head wont hold up. Is there anyway to check your head health with out disassembling it???
i have about 375+whp stock head..if that any usefull
Old Sep 30, 2008 | 05:31 PM
blinx9900's Avatar
Default Re: how to check your head?? (laziebun)
posting what kind of motor/head this is would help, also how many miles on it, what mods you have etc... i would be more worried about the head in regards to rpm increase than HP increase... 375+ is not that wild for an OEM head however 215whp at 9800rpm IS very wild, catch my drift?
Old Sep 30, 2008 | 05:35 PM
laziebun's Avatar
Default Re: how to check your head?? (blinx9900)
yeah im picking up what your putting down.....its a GSR fully built bottom end and redline at 8000rpm, but thinking putting the rev to 7500 to be on the SAFE SAFE side. Not realy sure how many miles on the head. But nothing is knocking.
Old Sep 30, 2008 | 05:53 PM
Fkned's Avatar
You can do a leakdown test to see if the valves seal.But I'd have the head taken apart to check the springs.
Old Oct 1, 2008 | 06:32 AM
blakkvtec's Avatar
Default Re: how to check your head?? (Fkned)
Resurface the valves, get some good supertech spring and you'll be fine. The only thing I would worry about is a valve starting to float in the high RPM's without good springs.
chad
Jul 7, 2011 09:27 PM
josh green
Jan 20, 2010 02:52 PM
Hybrid96EK
May 1, 2007 07:32 PM
JMinSi2000
Aug 16, 2004 08:11 PM
