How much boost can a mini me handle
Old Oct 9, 2008 | 06:56 PM
FERIO916's Avatar
Default How much boost can a mini me handle
i am running a mini me y7/y8 turboed i have the blue box set @ 5 psi but i want more motor is stock only has thicker head gasket (0.51 mm cometic) and arp head studs anyone else running boosted mini me ? whats the highest psi i can safley run it on of course tuned differently any input will be greatly apprieciated ohh yea and what kind of hp's can i expect to get with more psi thanks...............
Old Oct 9, 2008 | 07:46 PM
stiffdogg06's Avatar
Default Re: How much boost can a mini me handle (FERIO916)
My y8 has held 240whp DDed for 30k miles now. Completely stock. That's on a t3/t04e .50trim .63 ar. at 10-11psi
At 8psi, I had 208whp.
First get rid of the blue box.
Old Oct 9, 2008 | 08:28 PM
1.5Slowmatic's Avatar
Default Re: How much boost can a mini me handle (stiffdogg06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stiffdogg06 &raquo;</TD></TR><TR><TD CLASS="quote">My y8 has held 240whp DDed for 30k miles now. Completely stock. That's on a t3/t04e .50trim .63 ar. at 10-11psi
First get rid of the blue box. </TD></TR></TABLE>
agreed. get rid of the emange and convert to OBD1. Man your doing 240 on all stock? That must be a hell of a tune you got. Mad props to you dude .
Old Oct 9, 2008 | 09:55 PM
base-op.1320's Avatar
Default Re: How much boost can a mini me handle (1.5Slowmatic)
Its not how much psi can you run, its how much hp can you make safely. Psi is a changing factor on engines with different efficiency's
Old Oct 10, 2008 | 08:11 AM
Schister66's Avatar
Man U FTW
Default Re: How much boost can a mini me handle (base-op.1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by base-op.1320 &raquo;</TD></TR><TR><TD CLASS="quote">Its not how much psi can you run, its how much hp can you make safely. Psi is a changing factor on engines with different efficiency's</TD></TR></TABLE>
That's exactly the answer people need to hear. PSI in this case is ireelevant. Stock D series engines live comfortably in the 220-240whp range, but get a little finicky if you push them harder. Stay below that and youll be fine.
Old Oct 10, 2008 | 09:23 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FERIO916 &raquo;</TD></TR><TR><TD CLASS="quote">has thicker head gasket (0.51 mm cometic) and arp head studs</TD></TR></TABLE>
Its the rods and ringlands that are the weak link, and they can only take so much power. Lowering the compression just allows a bit more boost, mainly since each PSI makes less power. As long as its a good motor, it should take 10psi from any turbo up to a 60trim t3/t04e size. Beyond that and all bets are off. Its rather pointless to NOT go with a smaller turbo, since you just run more boost for the same power, but gain spool and usually more initial torque.
If you stick with the blue box, I'd stick to 5psi.
rotasol
Jul 21, 2009 03:16 PM
Ahknodd
Feb 22, 2009 05:57 PM
project civic
Jun 11, 2005 05:31 PM
eNRGyNiX
Apr 17, 2005 09:39 AM
CRAZYHONDA
Feb 27, 2005 11:02 AM
