Mercedes 300D T3 turbo question
Well I'm trying to piece together a turbo kit for a little more power for the stock D. I came across a T3 off of a 300D that is in good conditions. My question is has anyone used it before? Is is ok to run a diesel turbo on a gasoline engine? If someone has ran it at what RPM did you rearch full boost? Thanks in advance, any help is appreciated.
Re: Mercedes 300D T3 turbo question (Jeanious)
That turbo should do just fine for you man, I have ran diesel mercedes turbos on b18's before. Make sure you flush the turbo out real good before using it and clean it up real good.
