Ls vtec, which pistons to use?
Old Oct 7, 2008 | 04:42 PM
almostjdmeg's Avatar
Default Ls vtec, which pistons to use?
Im building an ls vtec right now. My setup is a b18a1 block with stock pistons, gsr water pump, arp rod bolts, gsr oil pump, and brand new gsr head. What kind of horsepower am i looking at with the stock ls pistons? Should i get some different pistons, or are these fine? I plan on boost, and some people told me that gsr pistons would be too high of compression, that i would get more horsepower out of just boosting with the stock ls rods. What do you guys think? Thanks
Old Oct 7, 2008 | 07:35 PM
tony413's Avatar
Default Re: Ls vtec, which pistons to use? (almostjdmeg)
run gsr pistons or get cam gear and notch the vavle reliefs of your LS pistons
Old Oct 8, 2008 | 08:08 AM
Default Re: Ls vtec, which pistons to use? (tony413)
What is notching the valve reliefs?
Old Oct 8, 2008 | 08:33 AM
DJYoshaBYD's Avatar
disregard that.. use the stock LS pistons for boost, or aftermarket pistons of the same compression ratio.. you want lower compression for boost than for NA.. GSR pistons would be fantastic, if you were going all motor
"notching the valve reliefs".. if you ever look at a piston, you will see dimples in it to make room for the valves, as this is an "interference motor".. that is why, when you break a timing belt, you bend valves, because they smack the pistons.. notching these areas on the pistons will make more clearance for your valves, if you start advancing the cam timing, as it will make the valves come closer to the pistons at full extension..
almostjdmeg
Oct 8, 2008 01:15 PM
recon23
Nov 6, 2007 04:50 AM
dumas07
Jul 4, 2006 07:06 AM
RAWB
Mar 23, 2003 03:51 PM
dustin
Nov 13, 2001 02:58 PM
